Received invalid 'digits' argument when using EIKON API R to pull data
Was using the Eikon API R to run a loop to pull data for various securities. When I returned to my computer and RStudio, I received this error:
Error in print.default("HTTP Error, code= ", response$status_code, sep = "") :
Was unsure what was the problem as it was abrupt. Here is the traceback:
6.  print.default("HTTP Error, code= ", response$status_code, sep = "")
5.  print("HTTP Error, code= ", response$status_code, sep = "")
4.  send_json_request(DataGrid_UDF_endpoint, payload, debug = debug)
3.  get_data(instruments = aSEDOL, fields = list("TR.RIC"))
2.  check_valid_sedol(aSEDOL)
1.  update_all(SEDOLused$SEDOL)
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonreikon-data-api-r
Hi all, I returned to my script the next day and ran it again and it worked. Maybe the servers were under maintenance or something.
23k 22 9 14
Hello @WestWinter,
Please be informed that Eikon API R is not officially supported by Refinitiv.
Sometimes we can answer a question, and in this case we will do so.
For a suspected issue report, it's best to discuss with the creator of Eikon API R at https://github.com/ahmedmohamedali/eikonapir
