Failover when using EMA Java
I am using EMA Java and now I need to implement failover, I understand that I need to use ChannelSets, but I can't find how to use them. Could someone please explain how I can add another server to use failover?
As explained in the sample code, I'm using the following line to provide the server details:
consumer  = EmaFactory.createOmmConsumer(EmaFactory.createOmmConsumerConfig().host("localhost:14002").username("user"));
is there another factory that would accept a channelset?
Thanks very much in advance.
Hi @tdlc
Please refer to my article on EMA Config which has a section on ChannelSets
https://developers.refinitiv.com/article/elektron-message-api-ema-configuration-overview
You can specify the ChannelSet in the EMAConfig.xml flat file. If you are not using a config file, you can use Programmatic Config to create a ChannelSet based config within your code.
Programmatic config is demonstrated in example example421__MarketPrice__ProgrammaticConfig. Note that the example does not include a ChannelSet - but you would replicate the structure described in the article withing your code.
I'll try that, thank you!
