I'm trying to use the ClientApp.sln project, but I've some problem with the proxy authentication and I dont' find any documentation about it: can you help me? I would like to know how i can set proxy server, username and password. Thanks in advance
I found a solution on stack overflow.
void SetProxySettings<TChannel>(ClientBase<TChannel> client, bool useProxy, string address, int port, string login, string password) where TChannel : class { if (!useProxy) return; var b = client.Endpoint.Binding as BasicHttpBinding; if (b == null) { System.Diagnostics.Debug.WriteLine("Binding of this endpoint is not BasicHttpBinding"); return; } b.ProxyAddress = new Uri(string.Format("http://{0}:{1}", address, port)); b.UseDefaultWebProxy = false; // !!! b.Security.Mode = BasicHttpSecurityMode.Transport; b.Security.Transport.ClientCredentialType = HttpClientCredentialType.None; // !!! b.Security.Transport.ProxyCredentialType = HttpProxyCredentialType.Basic; // !!! if (client.ClientCredentials == null) return; client.ClientCredentials.UserName.UserName = login; client.ClientCredentials.UserName.Password = password; }
For example:
using (var dsClient = new DSServiceClient()) { // Issue a call to get the token SetProxySettings(dsClient, true, "127.0.0.1", 8080, "admin", "password"); ...
Thanks for your solution. In configuration.svcinfo file there are some keys about proxy argument, I thought there was a directly callable method.
Hello @angelo.palumbo
The problem seems be be how to configure the proxy in Visual Studio application to run DataStream ClientApp demo and connects to DataStream Web Service from your company network.
I strongly suggest you contact your IT Network team to help you on setting proxy . You can find more detail regarding how to configure the proxy in Visual Studio from this post.
