Cannot conned to DSWS via python
Ran the code below to try and ID the issue per the recommendations posted:
import DatastreamDSWS as DSWS
import requests
import json
import os
url = "https://product.datastream.com/DSWSClient/V1/DSService.svc/rest/"
token_url = url + "GetToken"
def json_Request( raw_text):
    jsonText = json.dumps(raw_text)
    byteTemp = bytes(jsonText,'utf-8')
    byteTemp = jsonText.encode('utf-8')
    jsonRequest = json.loads(byteTemp)
    return jsonRequest
os.environ['HTTP_PROXY']="http://127.0.0.1:8080"
os.environ['HTTPS_PROXY']="http://127.0.0.1:8080"
tokenReq = {"Password":'<password>',"Properties":[{'Key':'__AppId','Value':"PythonLib 1.0"}],"UserName":'<username>'}
json_tokenReq = json_Request(tokenReq)
json_ResponseRaw = requests.post(token_url, json=json_tokenReq)
print(json_ResponseRaw.status_code, json_ResponseRaw.text)
json_Response = json_ResponseRaw.json()
print(json_Response["TokenValue"])
and got back:
ProxyError: HTTPSConnectionPool(host='product.datastream.com', port=443): Max retries exceeded with url: /DSWSClient/V1/DSService.svc/rest/GetToken (Caused by ProxyError('Cannot connect to proxy.', NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x000001C898EDBAC8>: Failed to establish a new connection: [WinError 10061] No connection could be made because the target machine actively refused it')))
pythondatastream-apidsws-apiproxy
@jgarden
The code uses the local proxy (http://127.0.0.1:8080). You need to make sure that you have a proxy installed on the machine. Otherwise, you can set it to another proxy or remove it.
#os.environ['HTTP_PROXY']="http://127.0.0.1:8080"
#os.environ['HTTPS_PROXY']="http://127.0.0.1:8080"
From my test, it can get the response properly when removing the above code.
