GetStandardFinancials_Request_1 Historical data (TRKD API)
Dear All, how are you? I´m trying to get the historical fundamental information using the
GetStandardFinancials_Request_1 in postman, but i'm unable to get the results due to this error:
"Fault": {
"Code": {
"Value": "s:Sender",
"Subcode": {
"Value": "a:Gateway_Validation_RequestError"
"Reason": {
"Text": {
"lang": "en-US",
"Value": "There was an error while converting from JSON request. The root object must contain only 'GetFinancialStatementsReports_Request_1'"
"Detail": {
"ClientErrorReference": {
"Timestamp": "2020-07-03T16:17:25.3205811Z",
"ErrorReference": "976732c1ad264169889c3d835ea221d9",
"ServerReference": "3E67AD1A68FE5CCCFCD0BB4CCBA2FD0733FCE201090FDCAA"
The Request in postman is:
"GetStandardFinancials_Request_1": {
"companyId": "IBM.N",
"companyIdType": "RIC",
"finStatement": "AIS",
"startDate": "2010-07-03",
"endDate": "2020-07-03",
"startFY": 0,
"endFY": 0,
"fpNumber": 0,
"showCompanyInfo": true,
"updateType": "MostRecent",
"completeStatement": "AllStatements",
"finalFiling": "AllFilings",
"lang": "en-US"
Anyone has a clue or can confirm me if is possible to get historical data for fundamentals via TRKD API?
Thanks in advance!!
rkd-apihistoricalrkdfundamentals
The problem has been solved, I made a mistake configuring the endpoint. The correct endpoint is { {protocol}}{ {host}}{ {api}}/Fundamentals/Fundamentals.svc/REST/Fundamentals_1/GetStandardFinancials_1, and this is working fine now.
