Python code Industry Classification TRKD
Hi Community,
Does anyone have a sample python script to select INDUSTRY CLASSIFICATION from TRKD?
Best,
Andrew
pythonrkd-apirkdfundamentalssectors
18k 21 12 20
Hi @andrew.davies
From theGet Industry Classification Schema Full Hierarchy call on TRKD catalog at LINK.
Here is the sample code:
import requests
import json
import sys
appid = raw_input('Please input appid: ')
token = raw_input('Please input token: ')
requestMsg1 = \
        "GetIndustryClassificationSchemaFullHierarchy_Request_1":
            "TaxonomyCode": "RBSS2004",
            "LanguageCode": "en-US"
requestURL = 'http://api.trkd.thomsonreuters.com/api/Fundamentals/Fundamentals.svc/REST/Fundamentals_1/GetIndustryClassificationSchemaFullHierarchy_1'
headers = {'content-type': 'application/json;charset=utf-8', 'X-Trkd-Auth-ApplicationID': appid, 'X-Trkd-Auth-Token': token}
result = requests.post(requestURL, data = json.dumps(requestMsg1), headers=headers)
resultText = result.text
print resultText.encode(sys.stdout.encoding, errors='replace')
You can inspect the JSON sample request on the TRKD catalog and change the code accordingly.
Red circle is URL endpoint which your request will be sent to.
Pink circle is a token generated from TRKD Create Service Token call.
Blue circle is an application ID assigned to your login.
Green circle is an input.
Here is the sample code to generate a token:
import requests
import json
import getpass
##get username, password and applicationid
username = raw_input('Please input username: ')
##use getpass.getpass to hide user inputted password
password = getpass.getpass(prompt='Please input password: ')
##create authentication request URL, message and header
#    "CreateServiceToken_Request_1":{
#      "ApplicationID": <application id>,
#      "Username": <username>,
#      "Password": <password>
authenMsg = {'CreateServiceToken_Request_1': { 'ApplicationID':appid, 'Username':username,'Password':password }}
authenURL = 'https://api.trkd.thomsonreuters.com/api/TokenManagement/TokenManagement.svc/REST/Anonymous/TokenManagement_1/CreateServiceToken_1'
headers = {'content-type': 'application/json;charset=utf-8'}
#send request
result = requests.post(authenURL, data = json.dumps(authenMsg), headers=headers)
if result.status_code == 200:
   print 'Request success'
   print 'response status %s'%(result.status_code)
   ##get Token
   token = result.json()['CreateServiceToken_Response_1']['Token']
   print 'Token: %s'%(token)
   ##get expiration
   expire = result.json()['CreateServiceToken_Response_1']['Expiration']
   print 'Expire: %s'%(expire)
elif result.status_code == 500:
   print 'Request fail'
   print 'Error: %s'%(result.json())
print result.text
#  "CreateServiceToken_Response_1": {
#    "Expiration": "2016-09-26T09:42:54.4335265Z",
#     "Token": "xxxxxxxxxx..."
Thanks very much for this, much appreciated!
Andrew
