emaj 3.4.0 tcp_nodelay socketopt set to False
Hi
We are using emaj3.4.0.L1.all.rrg and encountered problem with ommInteractive provider where the tcp_nodelay socketopt is either always set to False or omitting True value.
ommNIP and ommConsumer components do not experience such behavior and set the tcp_nodelay flag appropriately.
Can you advise where the problem may be.
Piotr
elektronrefinitiv-realtimeelektron-sdkrrtema-apielektron-message-apitcp
@piotr.g
I have verified the code. EMA Java may not use the TcpNodelay parameter when creating a server socket.
It should have this line in order to set tcp_nodelay.
_bindOptions.tcpOpts().tcpNoDelay(((SocketServerConfig)_activeServerConfig.server
Config).tcpNodelay);
You have two options:
1. Contact RDC subscribers inside your company in order to submit a new case to RDC via Contact Premium Support at https://developers.refinitiv.com/elektron/elektron-sdk-java
RDC will investigate this issue and then contact the development team if it is a bug in the API.
2. Raise this issue via GitHub as mentioned by my colleague
Thanks for the info, I'll pass it to our Dev team
9.5k 10 5 7
Hello @piotr.g
Have you tried emaj the latest version, 3.5.0.0, shipped with Elektron SDK - Java - 1.5.0.L1 package yet?
If the problem still occur with the latest version, you can submit the issue to the development team directly via Elektron-SDK Github
