I get the following error (see below with the code) when retrieving market data. My Eikon API with python has been working for months and only started failing yesterday. I contacted my account manager, nothing changed over the week-end on my account.. My Eikon app and Eikon add-in for Excel still work normally.
Simple code:
import eikon as ek
ek.set_app_key(xxxxxxxx)
spots = ek.get_data("EUR=", 'CF_LAST')
I get:
--------------------------------------------------------------------------- EikonError Traceback (most recent call last) <ipython-input-6-c8728b099fbf> in <module> 1 import eikon as ek 2 ek.set_app_key(eikonKey) ----> 3 spots = ek.get_data("EUR=", 'CF_LAST') \\ms\dist\python\PROJ\eikon\1.0.0\lib\eikon\data_grid.py in get_data(instruments, fields, parameters, field_name, raw_output, debug) 177 payload = {'instruments': instruments,'fields': fields_for_request} 178 if parameters: payload.update({'parameters': parameters}) --> 179 result = eikon.json_requests.send_json_request(DataGrid_UDF_endpoint, payload, debug=debug) 180 181 if raw_output: \\ms\dist\python\PROJ\eikon\1.0.0\lib\eikon\json_requests.py in send_json_request(entity, payload, debug) 98 return result 99 else: --> 100 raise_for_status(response) 101 102 except requests.exceptions.ConnectionError as connectionError: \\ms\dist\python\PROJ\eikon\1.0.0\lib\eikon\json_requests.py in raise_for_status(response) 189 if error_msg: 190 logger.error('Error code {} | {}'.format(response.status_code, error_msg)) --> 191 raise EikonError(response.status_code, error_msg) EikonError: Error code 404 | Client Error: Not Found - <!DOCTYPE html> <html lang="en"> <head> <meta charset="utf-8"> <title>Error</title> </head> <body> <pre>Cannot POST /api/v1/data</pre> </body> </html>
