Definition of "FID 8636:NA_MSG_TYP"
What is the definition of "FID 8636: NA_MSG_TYP"?
My system received the following What does this value mean and what other values, if any, do you have?
R,G,H,Y,Q,T,X,J
Best regards.
9.5k 10 5 7
Hello @imazu
From my finding, in RDMFieldDictionary shipped with Elektron-SDK-1.5.0.L1.java.rrg. The definition of the field id 8636 is shown below:
The field value is string type so the range of possible values can be any string. Hence, I would suggest you reach out to the feed/data support team who can answer this data question. You can submit queries to the feed/data team at Product Support | MyRefinitiv . Select Product to be a feed e.g. Thomson Reuters Elektron Real-Time .
For any data, fields, RICs questions, please contact the feed/data support team as I mentioned above.
This forum is dedicated to questions and discussions on developing applications using Refinitiv APIs, the majority of the members of the community are developers, the moderators of the forum are API experts.
