Which TREP version starts to support OptimizedPauseResume in RFA?
Furthermore, do consumer also need to include SupportOptimizedPauseResume Attrib in login request?
elektronrefinitiv-realtimetreprfa
We have tested this with ADS 2.4. After setting *ads*supportPauseResume to True, the login refresh from ADS contains both SupportPauseResume and SupportOptimizedPauseResume.
<attrib>
<elementList flags="0x8 (RSSL_ELF_HAS_STANDARD_DATA)">
<elementEntry name="AllowSuspectData" dataType="RSSL_DT_UINT" data="1"/>
<elementEntry name="ApplicationId" dataType="RSSL_DT_ASCII_STRING" data="256"/>
<elementEntry name="ApplicationName" dataType="RSSL_DT_ASCII_STRING" data="ADS"/>
<elementEntry name="Position" dataType="RSSL_DT_ASCII_STRING" data="10.29.181.35/net"/>
<elementEntry name="ProvidePermissionExpressions" dataType="RSSL _DT_UINT" data="1"/>
<elementEntry name="ProvidePermissionProfile" dataType="RSSL_DT_ UINT" data="0"/>
<elementEntry name="SingleOpen" dataType="RSSL_DT_UINT" data="1" />
<elementEntry name="SupportOMMPost" dataType="RSSL_DT_UINT" data ="1"/>
<elementEntry name="SupportPauseResume" dataType="RSSL_DT_UINT" data="1"/>
<elementEntry name="SupportStandby" dataType="RSSL_DT_UINT" data ="0"/>
<elementEntry name="SupportBatchRequests" dataType="RSSL_DT_UINT " data="1"/>
<elementEntry name="SupportViewRequests" dataType="RSSL_DT_UINT" data="1"/>
<elementEntry name="SupportOptimizedPauseResume" dataType="RSSL_ DT_UINT" data="1"/>
</elementList>
</attrib>
TREP 2.2.X and below have been end of life since June 30, 2014. The supported versions are 2.4 onward. TREP 2.4 supports OptimizedPauseResume.
Refer to RDM usage guide, SupportOptimizedPauseResume Attib is for login refresh sent by providers.
Is it SupportPauseResume attrib rather than SupportOptimizedPauseResume attrib in login refresh sent by provider?
