Hello @Hao.Tang
Please refer to DataScope Product Suite Connection Options + Requirements which identifies the current connection options for accessing DSS i.e. interface(API) with IP.
However, the clients are encouraged to access DataScope products via host-name-based URLs, not IP addresses. This is the recommended best practice as it requires no changes to client scripts or browser bookmarks in the event of a failover of the Production environment to the Disaster Recovery (DR) site.
In China host name is blocked and client can only use IP. When client use 192.165.219.152 by rest API, they got error 404 and cannot get token.
The file you shared is also incorrect. DR IP for internet rest API and FTP are both suspected
Hi @Hao.Tang,
It seems that the "RestApi" is missing from the endpoint. The endpoint URL should be:
https://192.165.219.152/RestApi/v1/Authentication/RequestToken
Also, you need to disable the certificate validation in the application.
