How to have DSWS to reference to data in a column?
I wanted to do a snapshot request of securities in a column. I saved my column data in a variable (eg A <- Select(Table_name, Ticker) ) and would like to invoke using the data inside this variable via:
myData <- mydsws$snapshotRequest(instrument = A,
datatype = "P",
requestDate = "0D")
But was returned with a Bad Request.
Thanks in advance.
datastream-apidsws-apir
@WestWinter
For example, I have items in a CSV file.
mydata = read.csv("items1.csv")
mydata
Then, the code is:
items <- mydata[['Symbol']]
myData <- mydsws$snapshotRequest(instrument =  items,
                                 datatype = "P",
                                 requestDate = "0D")
myData
@WestWinter
I can run it properly.
Please share the full code. You can also refer to an R example on GitHub.
Hi, I wanted the instrument line inside the code to reference a variable.
Sample code:
A <- select(Ticker_Table,Instrument)
So within Ticker, there is a column with numerous instrument names (eg. MSACWF$)
datatype = "P",
requestDate = "0D")
I tried inserting just one/a few instrument names and they work, but I would like them to work with data inside a column so I can just update the column itself, with the dataframe queried updated as well automatically.
