I want to download index data via the DatastreamDSWS2R Package using the following Code, which is basically given at the package description on github, but I changed the instrument to "DAXINDEX".
The code only returns the instrument. Using other indices like MSCI World or Eurostoxx 50 gives the same result.
> mydsws$timeSeriesRequest(instrument = "DAXINDEX", + #expression = "PCH#(XXXX, RI)", + datatype = "P", + startDate = "-30D", + endDate = "-0D", + frequency = "D") DAXINDEX>
Thank you very much,
best
Matthias
