Does EMA support the 32bit platform?
I noticed EMA only appears to support the 64bit platform. Does anyone know if there are plans to support 32bit as well? Thank you.
elektronrefinitiv-realtimeelektron-sdkrrtema-apielektron-message-apisupport32-bit
All APIs in the Elektron SDK are 64bit only as well as the latest versions of UPA and RFA (v8).
If you need a 32bit API then you must use a previous version of RFA or UPA.
Hi, is this still true? For RFA8 there is at least 32-bit C# API. We would like to use EMA but we are not able to switch to 64-bit. Is it really not possible to get 32-bit version? What is motivation for this?
