Using example "3.1.0 - Streaming - MarketPrice" and connecting via Eikon4
Replace the OnRefresh handler with the following code:
.OnRefresh((s,msg) => { Console.WriteLine(msg); using (IStream s_ = DeliveryFactory.CreateStream(new ItemStream.Params().Session(session).Name("CHF="))) { s_.Open(); Console.WriteLine("IT WORKED"); } })
The program does not return from s_.Open() and will never print "IT WORKED".
Same result when trying to await an OpenAsync() call.
