New DSWS user can't connect for Python 3.6
Hi, I'm a new Datastream WebServices user. I tried to connect to DatastreamDSWS via Python using the following code:
import DatastreamDSWS as DSWS
ds = DSWS.Datastream(username="XXXXXXX", password="XXXXXXXX")
but have been getting the following error:
_get_token : Exception Occured
(<class 'AttributeError'>, AttributeError("'str' object has no attribute 'name'"), <traceback object at 0x10f9b1320>)
None
Traceback (most recent call last):
  File "/opt/anaconda3/envs/recommendation_2020/lib/python3.7/site-packages/DatastreamDSWS/DS_Response.py", line 259, in _get_token
    verify=self.certfile.name).json()
AttributeError: 'str' object has no attribute 'name'
I'm assuming my DSWS account is active as was able to get a token from: http://product.datastream.com/DswsClient/Docs/TestSoapV1.aspx
datastream-apidsws-api
@howard.wen1
I can replicate this issue on the Linux system (Non-Windows). It looks like to be a bug in the library. The workaround is using this code:
import requests
ds = DSWS.Datastream(username = 'xxxxx', password = 'xxxx', sslCer=requests.certs.where())
You can also raise this issue via GitHub.
That did the trick. Thanks!
11.5k 16 7 10
Hello @howard.wen1
I cannot replicate the issue with DatastreamDSWS version 1.0.2 and Python versions 3.6.10, 3.7.7 in my environment.
Which version of DatastreamDSWS that you are using? You can use pip list command in your active environment to check the installed libraries versions.
(dsws36) C:\>pip list
Package         Version
certifi         2020.4.5.1
chardet         3.0.4
DatastreamDSWS  1.0.2
DateTime        4.3
idna            2.9
numpy           1.18.2
pandas          1.0.3
pip             20.0.2
python-dateutil 2.8.1
pytz            2019.3
requests        2.23.0
setuptools      46.1.3.post20200330
six             1.14.0
urllib3         1.25.8
wheel           0.34.2
wincertstore    0.2
zope.interface  5.1.0
