Confusion about primariness.
I want to check if a RIC is a primary instrument. For that, I usually use the formula TR.IsPrimaryInstrument (with a boolean output). Let's suppose I use this RIC: 00XJ.F, the outcome for this ticker and TR.IsPrimaryInstrument is 'true'.
But, when I use TR.IsPrimaryInstrument for a similar RIC (00XJ.DE) I get back that it is also a 'true' outcome to the same formula.
How is this possible? I would like to understand.
For example, when I check the RIC associated to other ID's, like ISIN, using TR.PrimaryInstrument, I get 00XJ.DE and not 00XJ.F
What should I use to define my criteria on primariness using these Eikon formulas? I'm a bit confused over this.
Thanks in advance for any guidance!
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonformula-builder
3.8k 4 4 6
Hi @aquilesjlp300
Try TR.IsPrimaryQuote or alternatively TR.PrimaryQuote.
df, err = ek.get_data(['00XJ.DE','00XJ.F'],['TR.IsPrimaryQuote','TR.PrimaryQuote'])
df
Thank you for this Marcin!
What is the difference then between TR.IsPrimaryInstrument and TR.IsPrimaryQuote?
Hi @aquilesjlp300 TR.isPrimaryInstrument - there could be several instruments issued for the single company. The particular instrument can have several different quotes and only one is selected as a PrimaryQuote based on the market cap.
Thanks for your valuable insight Marcin!
