What parameters to use in ek.get to specify the date when using TR.FundNAV data item?
I was previously using the field TR.NETASSETVAL which stops population CRUD.L after the 3rd of May. In python API, the Formula I was using: ek.get_data(['CRUD.L','USO'],['TR.NETASSETVAL.Date','TR.NETASSETVAL', {'SDate':startDate.isoformat(), 'EDate':endDate.isoformat()})[0]
I am now using the formula below but results are not sorted and I need to specify that I want the date. ek.get_data(['CRUD.L'],['TR.FundNAV.Date','TR.FundNAV'], {'SDate':startDate.isoformat(), 'EDate':endDate.isoformat()})[0] print rawnavs.tail()
To obtain exactly the same result in Python API, what parameters would you use in ek.get_data?
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonformula-builder
9.7k 49 38 60
Hi @Carmila.Lazo,
Can you provide an example of what your output looks like and where the sorting fails?
I tried a simplistic view of what you are doing and this is what the output looks like:
