I am hoping some of the experts here can shed some light on a warning message: Developer is seeing several of the following Warning message in his log file for the same stream;
11:57:09.869304 INF RDM/RDMClient.cpp(200)[0x7fd7877fe700] LoggerNotifyEvent from RSSL_Cons_Adapter2[Mon Jan 13 11:57:09 2014]: (ComponentName) RSSL_Cons_Adapter: (Severity) Warning: "Connection_RSSL" received message for a not registere d item: stream id = 204
11:57:09.869383 INF RDM/RDMClient.cpp(200)[0x7fd8127fc700] LoggerNotifyEvent from RSSL_Cons_Adapter2[Mon Jan 13 11:57:09 2014]: (ComponentName) RSSL_Cons_Adapter: (Severity) Warning: "Connection_RSSL" received message for a not registere d item: stream id = 204
followed by disconnect from the ADS.
11:57:09.940594 INF RDM/RDMClient.cpp(200)[0x7fd7877fe700] LoggerNotifyEvent from RSSL_Adapter1[Mon Jan 13 11:57:09 2014]: (ComponentName) RSSL_Adapter: (Severity) Information: RSSL Channel closing on connection "Default::Connection_RSSL p2psa.eur.nsroot.net:14002" due to "requested disconnect"
Has anyone come across the above warnings? Under what circumstances could a consumer client receive events for an unregistered item?
