Encode RsslSeries into RsslElementList
Hello
Trying to encode RsslSeries as an entry of RsslElementList and getting RSSL_RET_INVALID_DATA error, embedding RsslArray works fine though. Is embedding RsslSeries into another container not supported by the UPA C Toolkit?
Thanks.
elektronrefinitiv-realtimeelektron-sdktrepencodinginitialization
Thank you DevTrev
Already found the problem, it was my fault – hadn’t surrounded series encoding with SeriesInit/SeriesComplete routines.
It should be fine to encode a series in an element entry. Can you provide some code that shows how you are encoding them, and where the error occurs?
