add argument to JobGetCompleted API
How could we enter argument for the /Jobs/JobGetCompleted API, I see from the API Documentation that we could enter argument like the following, how could we add the argument to the query, and what is the format.
CompletionDateDateTime?
CreateDateDateTime?
Descriptionstring
JobIdstringPrimary Key MonitorUrlstringRead-Only ProgressPercentageint?
StartedDateDateTime?
StatusJobStatusCancelledCompletedErrorInProgressNotStartedPendingCancellationPurged
StatusMessagestring
UserIdint
@kai fang
Which API are you using? This forum is dedicated to Eikon APIs. The terms you mentioned don't look like anything related to any Eikon APIs.
@kai fang
Refer to the DSS REST API Reference Tree, those are return values.
There is no parameter for this function. The return value looks like:
"value": [
            "JobId": "0x0708d6bc6f41752d",
            "UserId": xxxx,
            "Status": "Completed",
            "StatusMessage": " ",
            "Description": "TickHistoryRawReportTemplate Extraction",
            "ProgressPercentage": 0,
            "CreateDate": "2020-03-27T02:39:13.356Z",
            "StartedDate": "2020-03-27T02:39:13.356Z",
            "CompletionDate": "2020-03-27T02:42:50.983Z",
            "MonitorUrl": "https://hosted.datascopeapi.reuters.com/RestApi/v1/Extractions/ExtractRawResult(ExtractionId='0x0708d6bc6f41752d')"
Thanks a lot! I'll try that out.
run 3
