Series of hstorical implied volatility for a list of RICs
Hi. I am quite new with Eikon Python API. I would like to ask how to get a series of historical Implied Volatility for a list of RICs. For example, close of day implied volatility from 2000-2010 for US energy sector. Thanks a lot.
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonhistorical
18k 21 12 20
Hi @songqirong
Thanks for the sample formula in Eikon Excel
Please try this code:
df,e = ek.get_data('VODATMIV.L',
                   ['TR.30DAYATTHEMONEYIMPLIEDVOLATILITYINDEXFORPUTOPTIONS.Date',
                    'TR.30DAYATTHEMONEYIMPLIEDVOLATILITYINDEXFORPUTOPTIONS'
                   {'SDate':'20140903','EDate':'20150902','Frq':'D'})
df.sort_index(ascending=False, inplace=True)
df
Output:
9.5k 10 5 7
Hello @songqirong
Eikon Python API provides get_timeseries(..) function which returns historical data on one or several RICs. The function can return the following fields: 'TIMESTAMP', 'VALUE', 'VOLUME', 'HIGH', 'LOW', 'OPEN', 'CLOSE', 'COUNT'
The example to get close price:
import pandas as pd
import eikon as ek
#set app key to identify the application on Eikon, Eikon Proxy or Refinitiv Platform
ek.set_app_key(<The application key>)
#get historical close price of RIC IBM.N from 2000-01-01 till 2010-12-31
df = ek.get_timeseries('IBM.N', 'CLOSE', interval='daily', start_date='2000-01-01', end_date='2010-12-31')
#display time series data frame
df
@songqirong
Typically, you can use the get_data method to get time series data. However, I am not sure Eikon can provide historical implied volatility. I only found the real-time field (IMP_VOLT) for implied volatility.
You can verify this by directly contacting the Eikon support team via MyRefiniiv and asking for the TR formula in Eikon Excel which can be used to retrieve historical implied volatility.
@jirapongse.phuriphanvichai
Thank you very much. I have got the TR formula to retrieve historical implied volatility. For example, =RHistory($B$1,"30D_A_IM_P.Timestamp;30D_A_IM_P.Value","START:"&$B$2&" END:"&$B$3&" INTERVAL:1D",,"CH:Fd",B5)
And the output looks like
May I ask whether I can adapt the excel formula to the "get_data" method in python API? One of the critical drawback of the excel plug in is that it takes quite a long time to update.
@chavalit.jintamalit Thanks a lot. I have just tried the code, it worked perfect!
