Historic get_data() for TR.AssetCharterer returns blank
I'm trying to get the charter history for oil tankers. It's possible to get this using `get_data()` on the `TR.AssetCharterer` field, as below:
`TR.AssetCharterer` is listed as a time series field in the Data Item Browser, yet whenever I try to get any historic data, either through `get_data()` or `get_timeseries()` it returns an empty string:
This holds true whether I'm specifying a specific date, a relative date or a range. Am I misunderstanding `TR.AssetCharterer` as a data point, or is this an issue with the API?
Any help would be much appreciated!
Louis.
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonhistorical
18k 21 12 20
Hi @lgoddard
I think it is about the content available and your parameters.
So your API call hit another record which has "Charterer" as blank.
Please try this: (I add 2 more fields to show the difference between each blank value)
rics = 'C}KM7309484069'
fields = ['TR.AssetLoadingDateFrom',
          'TR.AssetLoadingDateTo',
          'TR.AssetCharterer']
parameters = {'SDate':'2015-01-01', 'EDate':'2020-03-27', 'TOP':'100'}
df,e = ek.get_data(rics, fields, parameters)
df
Hi @chavalit.jintamalit - that's perfect, thank you. I should have explored the data a bit more before posting!
