Bloomberg R user switching to Eikon/eikonapir - sample R scripts/field mappings
R, eikonapir
I switched from many years as Bloomberg R user to Eikon, installed the R eikonapir library and used get_timeseries() to retrieve historical data mainly equity related.
My problem: Mapping of Bloomberg fields to Eikon. I use the Eikon Excel formula builder, but these fields don't seem to work. Example, in Excel Eikon shows for Closing Price the field TR.PriceClose but there is no data using (only using get_data() for last price).
get_timeseries(list("MSFT.O","VOD.L"),
list("TIMESTAMP","TR.PriceClose"),
"2020-01-01T00:00:00",
"2020-01-10T00:00:00")
Replacing TR.PriceClose with Close does work:
list("TIMESTAMP","CLOSE"),
"2020-01-01T15:04:05",
"2020-01-10T15:04:05")
Question: Does anyone has a reasonable R sample script downloading the usual items, like volume, 30 days ADV, shares outstanding, PE ratios
Many thanks!
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonreikon-data-api-rsample-code
@HeikoRR
When using the TR function in Eikon Excel to retrieve the data, you need to use the get_data method in the R eikonapir library to get the same data. For example:
data_frame2 <- get_data(list("MSFT.O","VOD.L"),
                        list("TR.PriceClose.Date","TR.PriceClose","TR.Volume","TR.SharesOutstanding","TR.PE","TR.AvgDailyVolume30D"),
                        list("Frq"="D","SDate"="2020-01-01","EDate"="2020-01-10"))
data_frame2
However, you need to contact the Eikon Excel support team via MyRefinitiv and ask for fields that can be used with the TR function to get the required data.
Many thanks - works perfectly!
