Blank data in field (FID) 1352
I am converting RDF data from Marketfeed to OMM on their ADH. When doing so, I noticed that field 1352 is blank when I request either XAU= or XAG=. I see the data when I request it directly from the RDF but not from their ADS. I also checked the ADH cache and it is blank there as well.
elektronrefinitiv-realtimetreprfafields
Not blank per say but char rep is expanded to fill the line with spaces. 31 to be exact. ADH cache should definitely look that way. So below text Do you have conflation enabled in ADH or ADS? If so, cache will expand partial updates. It is the same ending value, just that ADS/ADH is sending more bytes than necessary.
MF to OMM conversion logic does not expand the escape sequences. It is a direct copy so should be passed through as is. For this to be expanded, update must be getting extracted from cache instead of being just passed through. Mechanisms that do this are Conflation, Dynamic Views, Fid filtering, Traffic Management
