php return 401 Unauthorized response, but postman success
I have a class created in php, which generates a string that I send to the world-check one api to create a case, but when I consult, I get this error:
GuzzleHttp \ Exception \ ClientException (401)
Client error: `POST https: // rms-world-check-one-api-pilot.thomsonreuters.com / v2 / cases / screeningRequest` resulted in a` 401 Unauthorized` response
When I show the string that I generate, I copy and paste it to postman with the same url I use from the class, it works, but from a project in Laravel, I don't
world-checkworld-check-oneerror-401postmanphp
2.4k 5 5 5
@luis.macedo
401 errors occur because the request has failed an authorization check. This can happen for a variety of reasons, such as
  • An invalid or expired API key,
  • An invalid HMAC signature.
  • Request timing issue/problem with the Date header value. The API client must ensure a correctly synchronized clock is used to generate request timestamps.
  • Incorrect JSON payload formation at your end that can cause a 401 response.
To further investigate this and isolate the cause, can you please share the complete request and response headers of the failed API call?
Hello @Mehran.Ahmed Khan,
What time is needed? GMT or UTC, check on postman Refinitiv documentation and see this params:
2.4k 5 5 5
@luis.macedo
As you see the pre-request script postman automatically has the time synced with the GMT time.
I was referring to the request time header from your php code to be in sync with the GMT time.
Let me know if you would like to get on a quick meeting and take a look at this.
Regards
