I am trying to get a simple get request to work in php, that I've accomplished with postman without issue.
In postman, the outputted http code is the following:
GET /v1/cases/0a599156-6eb7-1e40-9bb3-2aae00039721 HTTP/1.1
Host: rms-world-check-one-api-pilot.thomsonreuters.com
Date: Fri, 06 Dec 2019 16:22:22 GMT
Authorization: Signature keyId="0b8f7e24-16d0-4672-9234-9b07b84d90d3",algorithm="hmac-sha256",headers="(request-target) host date",signature="N48t26VhJFS9KQZOqqIRumanWxfZEWwzJcRDF76f07c="
User-Agent: PostmanRuntime/7.19.0
Accept: */*
Cache-Control: no-cache
Postman-Token: d193cb45-f40d-4231-ad73-a203f00357b9,be6e8a64-807b-4184-88d3-fb1a0772b282
Accept-Encoding: gzip, deflate
Connection: keep-alive
cache-control: no-cache
my php code is as follows:
$curl = curl_init(); curl_setopt_array($curl, array( CURLOPT_URL => "https://rms-world-check-one-api-pilot.thomsonreuters.com/v1/cases/0a599156-6eb7-1e40-9bb3-2aae00039721", CURLOPT_RETURNTRANSFER => true, CURLOPT_ENCODING => "", CURLOPT_MAXREDIRS => 10, CURLOPT_TIMEOUT => 30, CURLOPT_HTTP_VERSION => CURL_HTTP_VERSION_1_1, CURLOPT_CUSTOMREQUEST => "GET", CURLOPT_POSTFIELDS => "", CURLOPT_HTTPHEADER => array( "Accept: */*", "Accept-Encoding: gzip, deflate", "Authorization: Signature keyId=\"0b8f7e24-16d0-4672-9234-9b07b84d90d3\",algorithm=\"hmac-sha256\",headers=\"(request-target) host date\",signature=\"N48t26VhJFS9KQZOqqIRumanWxfZEWwzJcRDF76f07c=\"", "Cache-Control: no-cache", "Connection: keep-alive", "Date: Fri, 06 Dec 2019 16:22:22 GMT", "Host: rms-world-check-one-api-pilot.thomsonreuters.com", "cache-control: no-cache" ), )); $response = curl_exec($curl); $info = curl_getinfo($curl); $err = curl_error($curl); curl_close($curl); if ($err) { echo "cURL Error #:" . $err; } else { echo print_r($response); } echo print_r($info);
And $response is always blank, and $info always shows me a 401 status code.
