No start and end time in the response of HistoricalChainResolution?
Good day experts,
I'm trying the 'get historical chain' operation, the request body is:
"Request": {
"ChainRics": [
"0#.SPX"
"Range": {
"Start": "2008-01-01T00:00:00.000Z",
"End": "2008-01-01T00:00:00.000Z"
And the response looks like:
"Constituents": [
"Identifier": ".SPX",
"IdentifierType": "Ric",
"Source": "",
"Key": "VjF8MHgzMDAwMDAwMDAwMDAwMDAwfDB4MzAwMDAwMDAwMDAwMDAwMHx8fHx8fHwuU1BYfA",
"Description": "Historical Instrument",
"InstrumentType": "Unknown",
"Status": "Valid",
"DomainCode": "6"
It missed the 'Start' and 'End' time fields?
e.g., in the ' TICK HISTORY FOR DATASCOPE SELECT 13.2 REST API USER GUIDE''s example:
"Constituents": [
"Identifier": "HOF0",
"Source": "",
"Key": "VjF8MHgzMDAwMDAwMDAwMDAwMDAwfDB4MzAwMDAwMDAwMDAwMDAwMHx8fHx8fHxIT0Ywf
A",
"Status": "Valid",
"DomainCode": "6",
Is that true or I miss some settings in the http request?
Best Regards,
Frederic
tick-history-rest-apichain-ric
11.3k 25 8 13
Hi @Frederic.Li,
I have verified the returned value of HistoricalChainResolution in the API Reference Tree and Metadata. There is no Start and End time field in response, so it likely is that the example result in the REST API User Guide document is not correct. To get the Valid Start and End time, you can pass the Constituents to HistoricalBulkSearch
I will contact TRTH support to verify the issue.
Thank you Veerapath, looks like the HistoricalBulkSearch does not touch/display the history chain itself and when a constituent was added into that chain.
