grab chainric data through rest api
We are trying to pull data associated to a specific chainRic, 0#SPX*.U, using a rest api GET command. We were hoping to pull either the specific identifiers associated to the chain or even better specific fields for each identifier in the chain for a specific date. Can you help us with an example GET command?
We have only been able to get the
https://hosted.datascopeapi.reuters.com/RestApi/v1/Search/HistoricalChainResolution uri to work for the 0#.SPX chainRic, and for some reason the 0#SPX*.U did not work when we swapped it out.
Any help is appreciated!
Thanks,
Will
tick-history-rest-apirest-apichain-ricderivatives
23k 22 9 14
To retrieve the constituents of the chain RIC, at specific dates, you may try HistoricalReference request:
    "ExtractionRequest": {
        "@odata.type": "#ThomsonReuters.Dss.Api.Extractions.ExtractionRequests.HistoricalReferenceExtractionRequest",
        "ContentFieldNames": [
            "RIC",
            "CUSIP",
            "ISIN",
            "SEDOL",
            "Issuer OrgID",
            "Exchange Code",
            "Currency Code",
            "Change Date"
        "IdentifierList": {
            "InstrumentIdentifiers": [
                    "Identifier": "0#SPX*.U",
                    "IdentifierType": "ChainRIC"
            "ValidationOptions": {"AllowHistoricalInstruments": true},
            "UseUserPreferencesForValidationOptions": false
        "Condition": {
            "StartDate": "2017-09-01T00:00:00.000Z",
            "EndDate": "2017-09-01T23:59:59.999Z"
Thanks for the response @zoya.farberov
I used your example, and the request is accepted but I'm getting an empty file. Here is the request with the headers:
The postsed data is exactly the same as above. Any thoughts as to why the file would return empty?
GET 'https://hosted.datascopeapi.reuters.com/RestApi/v1/Extractions/Extract'
Content-Type: application/json
Prefer: respond-async
Accept-Charset: UTF-8
Authorization: Token _token_
