The endpoint /Extractions/InstrumentListExists, and others in same category as documented in online API Reference Tree are invalid. The correct call to this method will be through endpoint: Extractions/InstrumentLists(ListId='xxxx').
The response does not contain a boolean either, but a JSON error object.
