Historical Reference for RIC identifier: All identifier invalid. No Extraction performed
I try to extract the Historical reference for certain RICs. It works with ChainRICs but when I enter a RIC, there is an error of invalid identifier.
See the code example
 string[] requestedFieldNames = {
"RIC",
"RIC Root",
"Expiration Date"};
//Create the request
var extractionRequest = new HistoricalReferenceExtractionRequest()
{ IdentifierList = new InstrumentIdentifierList()
{ InstrumentIdentifiers = new[] { new InstrumentIdentifier { IdentifierType = IdentifierType.Ric, Identifier = "HOZ5" } }
Condition = new HistoricalReferenceCondition()
{ ReportDateRangeType = ReportDateRangeType.Range,
//QueryStartDate = new DateTimeOffset(new DateTime(2014, 1, 1)),
//QueryEndDate = new DateTimeOffset(new DateTime(2014, 1, 31))
QueryStartDate = new DateTimeOffset(new DateTime(2015, 12, 1)),
QueryEndDate = new DateTimeOffset(new DateTime(2015, 12, 4))
ContentFieldNames = requestedFieldNames
  //Extract - NOTE: If the extraction request takes more than 30 seconds the async mechansim will be used.  See Key Mechanisms
var extractionResult = ExtractionsContext.ExtractWithNotes(extractionRequest);
var extractedRows = extractionResult.Contents;
dss-rest-apitick-history-rest-apiricshistoricalrest-api
13.7k 26 8 12
@dirk, yes you are right of course. Sorry, my mistake, I was looking for a current instrument, not a historical one.
When I use your code I get a "Not found" error, and the extraction notes contain:
All identifiers were invalid.  No extraction performed.
Cause: by default historical instruments are not included in the results.
Solution: you need to add a validation option to allow historical instruments. The following code should get the data you want:
        ValidationOptions = new InstrumentValidationOptions() {
            AllowHistoricalInstruments = true
        QueryStartDate = new DateTimeOffset(new DateTime(2015, 12, 01)),
        QueryEndDate = new DateTimeOffset(new DateTime(2015, 12, 04))
Just to illustrate, the following code sets all validation options, and disables the user preferences for this call (because we are overriding them with our validation options):
            AllowHistoricalInstruments = true,
            AllowOpenAccessInstruments = false,
            UseExchangeCodeInsteadOfLipper = true,
            ExcludeFinrAsPricingSourceForBonds = false,
            UseConsolidatedQuoteSourceForCanada = false,
            UseConsolidatedQuoteSourceForUsa = false,
            UseUsQuoteInsteadOfCanadian = true
        UseUserPreferencesForValidationOptions = false
Hope this helps.
13.7k 26 8 12
@dirk, the RIC instrument identifier is defined correctly. The issue is that HOZ5 is not a valid RIC.
Sorry, HOZ5 is a valid RIC. E.g. if I expand the ChainRIC 0#HO: I get HOZ5 as a RIC for the December 2015 Heating Oil Future.
Also, If I do the request 1) with the GUI or 2) creating instrument lists and a report template, it works. So this seems a Bug on your side.
See here for HOZ5 as RIC
see my answer above, HOZ5 is a valid RIC
Is it possible to match permno (identifier from CRSP) with RIC using a similar code to the one you used above?
