I have received a new account with machine id:
GE-A-01641484-3-2729
I think this account is for viewing Refinitiv data using the EMA java library.
Could you confirm if this account is indeed for viewing Refinitiv data using the EMA java library?
Assuming the account is for the above purpose, I have tried using the account and connecting to:
chp02-emea1.thomsonreuters.com
and specifying serviceName: DDS_TRCE.
I appear to login successfully to Refinitiv. However, the stream is always closed with:
2020-02-11T17:18:28,846 TunnelStreamListener [pool-3-thread-1] INFO : TunnelStreamListener.onAllMsg StatusMsg streamId="5" domain="System Domain" privateStream state="Closed / Suspect / Not entitled / 'TRCE not configured'" name="TUNNEL1" serviceId="10" serviceName="DDS_TRCE"StatusMsgEnd
Looking at the documentation for EMA Java, all Refinitiv examples use serviceName: DIRECT_FEED.
However, when trying to use the DIRECT_FEED service instead of DDS_TRCE I receive an OmmInvalidUsageException:
2020-02-11T17:26:56,302 RefinitivConnector [refinitiv-connector-thread-1] ERROR: Failure connecting to Refinitiv: Exception Type='OmmInvalidUsageException', Text='Attempt to get servieId while it is not set.'
Could someone confirm that we should connect to the chp02-emea1.thomsonreuters.com endpoint with this GE-A-01641484-3-2729 account?
Also - any pointers as to how to use this account to view data would be appreciated.
Note that I am using a TunnelStream as I am specifying RSSL_ENCRYPTED.
The TunnelStreamListener is called back with a StatusMsg after registering as a client - code snippets:
private OmmConsumer createOmmConsumer() { return EmaFactory.createOmmConsumer( EmaFactory.createOmmConsumerConfig(config.emaConfigFilePath()) .username(config.account()) .password(config.password()) .tunnelingKeyStoreFile(config.keyStoreFilePath()) .tunnelingKeyStorePasswd("password") ); } private static ClassOfService createClassOfService() { return EmaFactory.createClassOfService() .authentication(EmaFactory.createCosAuthentication().type(CosAuthentication.CosAuthenticationType.OMM_LOGIN)) .dataIntegrity(EmaFactory.createCosDataIntegrity().type(CosDataIntegrity.CosDataIntegrityType.RELIABLE)) .flowControl(EmaFactory.createCosFlowControl().type(CosFlowControl.CosFlowControlType.BIDIRECTIONAL).recvWindowSize(1200)) .guarantee(EmaFactory.createCosGuarantee().type(CosGuarantee.CosGuaranteeType.NONE)); } private void connectTunnelStream(final OmmConsumer ommConsumer, final ClassOfService classOfService) { final TunnelStreamListener client = new TunnelStreamListener(ommConsumer, callbacks, this::reconnect, config); final TunnelStreamRequest tsr = EmaFactory.createTunnelStreamRequest() .classOfService(classOfService) .domainType(EmaRdm.MMT_SYSTEM) .name("TUNNEL1") .serviceName("DDS_TRCE"); ommConsumer.registerClient(tsr, client); // <-- call is successful with DDS_TRCE, throws OmmInvalidUsageException with DIRECT_FEED }
but the tunnel stream is not open:
@Override public void onStatusMsg(final StatusMsg statusMsg, final OmmConsumerEvent consumerEvent) { final long tunnelStreamHandle = consumerEvent.handle(); if (statusMsg.state().streamState() != OmmState.StreamState.OPEN) { LOGGER.warn("Tunnel stream went down, will attempt to reconnect if not shutting down"); this.callbacks.refinitivConnectionDownCallback().onConnectionDown(); this.connectionDownListener.onConnectionDown(); } else { // Never gets here - tunnel stream is not open ommConsumer.registerClient( EmaFactory.createReqMsg().serviceId(1).name("A_RIC"), new SubStreamListener(ommConsumer, callbacks), 1, tunnelStreamHandle ); }
The following shows logs and tracing:
2020-02-12T13:54:29,271 RefinitivConnector [refinitiv-connector-thread-1] INFO : Connecting to Refinitiv... <!-- Outgoing Reactor message --> <!-- java.nio.channels.SocketChannel[connected local=/192.168.1.11:50726 remote=chp02-emea1.thomsonreuters.com/155.46.24.14:443] --> <!-- Wed Feb 12 13:54:31 GMT 2020 --> <!-- rwfMajorVer="14" rwfMinorVer="1" --> <REQUEST domainType="LOGIN" streamId="1" containerType="NO_DATA" flags="0x04 (STREAMING)" dataSize="0"> <key flags="0x26 (HAS_NAME|HAS_NAME_TYPE|HAS_ATTRIB)" name="GE-A-01641484-3-2729" nameType="1" attribContainerType="ELEMENT_LIST"> <attrib> <elementList flags="0x08 (HAS_STANDARD_DATA)"> <elementEntry name="ApplicationId" dataType="ASCII_STRING" data="256"/> <elementEntry name="ApplicationName" dataType="ASCII_STRING" data="ema"/> <elementEntry name="Position" dataType="ASCII_STRING" data="ppp"/> <elementEntry name="Password" dataType="ASCII_STRING" data="xxx"/> <elementEntry name="Role" dataType="UINT" data="0"/> </elementList> </attrib> </key> <dataBody> </dataBody> </REQUEST> <!-- Incoming Reactor message --> <!-- java.nio.channels.SocketChannel[connected local=/192.168.1.11:50726 remote=chp02-emea1.thomsonreuters.com/155.46.24.14:443] --> <!-- Wed Feb 12 13:54:31 GMT 2020 --> <!-- rwfMajorVer="14" rwfMinorVer="1" --> <REFRESH domainType="LOGIN" streamId="1" containerType="NO_DATA" flags="0x168 (HAS_MSG_KEY|SOLICITED|REFRESH_COMPLETE|CLEAR_CACHE)" groupId="0" State: Open/Ok/None - text: "" dataSize="0"> <key flags="0x26 (HAS_NAME|HAS_NAME_TYPE|HAS_ATTRIB)" name="GE-A-01641484-3-2729" nameType="1" attribContainerType="ELEMENT_LIST"> <attrib> <elementList flags="0x08 (HAS_STANDARD_DATA)"> <elementEntry name="ApplicationId" dataType="ASCII_STRING" data="256"/> <elementEntry name="ApplicationName" dataType="ASCII_STRING" data="ema"/> <elementEntry name="Position" dataType="ASCII_STRING" data="ppp"/> <elementEntry name="SingleOpen" dataType="UINT" data="0"/> <elementEntry name="SupportOMMPost" dataType="UINT" data="1"/> <elementEntry name="SupportBatchRequests" dataType="UINT" data="5"/> </elementList> </attrib> </key> <dataBody> </dataBody> </REFRESH> <!-- Outgoing Reactor message --> <!-- java.nio.channels.SocketChannel[connected local=/192.168.1.11:50726 remote=chp02-emea1.thomsonreuters.com/155.46.24.14:443] --> <!-- Wed Feb 12 13:54:31 GMT 2020 --> <!-- rwfMajorVer="14" rwfMinorVer="1" --> <REQUEST domainType="SOURCE" streamId="2" containerType="NO_DATA" flags="0x04 (STREAMING)" dataSize="0"> <key flags="0x08 (HAS_FILTER)" filter="63"/> <dataBody> </dataBody> </REQUEST> <!-- Incoming Reactor message --> <!-- java.nio.channels.SocketChannel[connected local=/192.168.1.11:50726 remote=chp02-emea1.thomsonreuters.com/155.46.24.14:443] --> <!-- Wed Feb 12 13:54:31 GMT 2020 --> <!-- rwfMajorVer="14" rwfMinorVer="1" --> <REFRESH domainType="SOURCE" streamId="2" containerType="MAP" flags="0x168 (HAS_MSG_KEY|SOLICITED|REFRESH_COMPLETE|CLEAR_CACHE)" groupId="0" State: Open/Ok/None - text: "" dataSize="249"> <key flags="0x08 (HAS_FILTER)" filter="63"/> <dataBody> <map flags="0x00" countHint="0" keyPrimitiveType="UINT" containerType="FILTER_LIST" > <mapEntry flags="0x00" action="ADD" key="10" > <filterList containerType="ELEMENT_LIST" countHint="0" flags="0x00"> <filterEntry id="1" action="SET" flags="0x00" containerType="ELEMENT_LIST"> <elementList flags="0x08 (HAS_STANDARD_DATA)"> <elementEntry name="Name" dataType="ASCII_STRING" data="DDS_TRCE"/> <elementEntry name="Vendor" dataType="ASCII_STRING" data="Thomson Reuters RTTG Core Development"/> <elementEntry name="Capabilities" dataType="ARRAY"> <array itemLength="0" primitiveType="UINT"> <arrayEntry data="6"/> <arrayEntry data="127"/> </array> </elementEntry> <elementEntry name="QoS" dataType="ARRAY"> <array itemLength="0" primitiveType="QOS"> <arrayEntry Qos: Realtime/TickByTick/Static - timeInfo: 0 - rateInfo: 0/> </array> </elementEntry> </elementList> </filterEntry> <filterEntry id="2" action="SET" flags="0x00" containerType="ELEMENT_LIST"> <elementList flags="0x08 (HAS_STANDARD_DATA)"> <elementEntry name="ServiceState" dataType="UINT" data="1"/> <elementEntry name="AcceptingRequests" dataType="UINT" data="1"/> <elementEntry name="Status" dataType="STATE" State: Open/Ok/None - text: ""/> </elementList> </filterEntry> <filterEntry id="4" action="SET" flags="0x00" containerType="ELEMENT_LIST"> <elementList flags="0x08 (HAS_STANDARD_DATA)"> <elementEntry name="OpenWindow" dataType="UINT" data="6"/> </elementList> </filterEntry> <filterEntry id="6" action="SET" flags="0x02 (HAS_CONTAINER_TYPE)" containerType="MAP"> <map flags="0x00" countHint="0" keyPrimitiveType="ASCII_STRING" containerType="ELEMENT_LIST" > <mapEntry flags="0x00" action="ADD" key="DDS_TRCE" > <elementList flags="0x08 (HAS_STANDARD_DATA)"> <elementEntry name="Type" dataType="UINT" data="1"/> <elementEntry name="LinkState" dataType="UINT" data="1"/> </elementList> </mapEntry> </map> </filterEntry> </filterList> </mapEntry> </map> </dataBody> </REFRESH> 2020-02-12T13:54:31,426 RefinitivConnector [refinitiv-connector-thread-1] INFO : Setting OmmConsumer 2020-02-12T13:54:31,434 RefinitivConnector [refinitiv-connector-thread-1] INFO : ... connected to Refinitiv <!-- Outgoing Reactor message --> <!-- java.nio.channels.SocketChannel[connected local=/192.168.1.11:50726 remote=chp02-emea1.thomsonreuters.com/155.46.24.14:443] --> <!-- Wed Feb 12 13:54:31 GMT 2020 --> <!-- rwfMajorVer="14" rwfMinorVer="1" --> <REQUEST domainType="SYSTEM" streamId="3" containerType="FILTER_LIST" flags="0x1144 (STREAMING|HAS_QOS|PRIVATE_STREAM|QUALIFIED_STREAM)" Qos: Realtime/TickByTick/Static - timeInfo: 0 - rateInfo: 0 dataSize="171"> <key flags="0x0B (HAS_SERVICE_ID|HAS_NAME|HAS_FILTER)" serviceId="10" name="TUNNEL1" filter="15"/> <dataBody> <filterList containerType="ELEMENT_LIST" countHint="0" flags="0x00"> <filterEntry id="1" action="SET" flags="0x02 (HAS_CONTAINER_TYPE)" containerType="ELEMENT_LIST"> <elementList flags="0x08 (HAS_STANDARD_DATA)"> <elementEntry name=":ProtocolType" dataType="UINT" data="0"/> <elementEntry name=":ProtocolMajorVersion" dataType="UINT" data="14"/> <elementEntry name=":ProtocolMinorVersion" dataType="UINT" data="1"/> <elementEntry name=":StreamVersion" dataType="UINT" data="2"/> </elementList> </filterEntry> <filterEntry id="2" action="SET" flags="0x02 (HAS_CONTAINER_TYPE)" containerType="ELEMENT_LIST"> <elementList flags="0x08 (HAS_STANDARD_DATA)"> <elementEntry name=":Type" dataType="UINT" data="1"/> </elementList> </filterEntry> <filterEntry id="3" action="SET" flags="0x02 (HAS_CONTAINER_TYPE)" containerType="ELEMENT_LIST"> <elementList flags="0x08 (HAS_STANDARD_DATA)"> <elementEntry name=":Type" dataType="UINT" data="1"/> <elementEntry name=":RecvWindowSize" dataType="INT" data="1200"/> </elementList> </filterEntry> <filterEntry id="4" action="SET" flags="0x02 (HAS_CONTAINER_TYPE)" containerType="ELEMENT_LIST"> <elementList flags="0x08 (HAS_STANDARD_DATA)"> <elementEntry name=":Type" dataType="UINT" data="1"/> </elementList> </filterEntry> </filterList> </dataBody> </REQUEST> <!-- Incoming Reactor message --> <!-- java.nio.channels.SocketChannel[connected local=/192.168.1.11:50726 remote=chp02-emea1.thomsonreuters.com/155.46.24.14:443] --> <!-- Wed Feb 12 13:54:31 GMT 2020 --> <!-- rwfMajorVer="14" rwfMinorVer="1" --> <REFRESH domainType="SYSTEM" streamId="3" containerType="FILTER_LIST" flags="0x4568 (HAS_MSG_KEY|SOLICITED|REFRESH_COMPLETE|CLEAR_CACHE|PRIVATE_STREAM|QUALIFIED_STREAM)" groupId="0" State: Open/Ok/None - text: "" dataSize="232"> <key flags="0x0B (HAS_SERVICE_ID|HAS_NAME|HAS_FILTER)" serviceId="10" name="TUNNEL1" filter="15"/> <dataBody> <filterList containerType="ELEMENT_LIST" countHint="0" flags="0x00"> <filterEntry id="1" action="SET" flags="0x00" containerType="ELEMENT_LIST"> <elementList flags="0x08 (HAS_STANDARD_DATA)"> <elementEntry name=":MaxMsgSize" dataType="UINT" data="614400"/> <elementEntry name=":MaxFragmentSize" dataType="UINT" data="6144"/> <elementEntry name=":SupportsFragmentation" dataType="UINT" data="1"/> <elementEntry name=":ProtocolType" dataType="UINT" data="0"/> <elementEntry name=":ProtocolMajorVersion" dataType="UINT" data="14"/> <elementEntry name=":ProtocolMinorVersion" dataType="UINT" data="1"/> <elementEntry name=":StreamVersion" dataType="UINT" data="2"/> </elementList> </filterEntry> <filterEntry id="2" action="SET" flags="0x00" containerType="ELEMENT_LIST"> <elementList flags="0x08 (HAS_STANDARD_DATA)"> <elementEntry name=":Type" dataType="UINT" data="1"/> </elementList> </filterEntry> <filterEntry id="3" action="SET" flags="0x00" containerType="ELEMENT_LIST"> <elementList flags="0x08 (HAS_STANDARD_DATA)"> <elementEntry name=":Type" dataType="UINT" data="1"/> <elementEntry name=":RecvWindowSize" dataType="INT" data="750000"/> </elementList> </filterEntry> <filterEntry id="4" action="SET" flags="0x00" containerType="ELEMENT_LIST"> <elementList flags="0x08 (HAS_STANDARD_DATA)"> <elementEntry name=":Type" dataType="UINT" data="1"/> </elementList> </filterEntry> </filterList> </dataBody> </REFRESH> <!-- Outgoing Reactor message --> <!-- java.nio.channels.SocketChannel[connected local=/192.168.1.11:50726 remote=chp02-emea1.thomsonreuters.com/155.46.24.14:443] --> <!-- Wed Feb 12 13:54:31 GMT 2020 --> <!-- rwfMajorVer="14" rwfMinorVer="1" --> <GENERIC domainType="SYSTEM" streamId="3" containerType="MSG" flags="0x19 (HAS_EXTENDED_HEADER|HAS_SEQ_NUM|MESSAGE_COMPLETE)" seqNum="1" dataSize="175"> <extendedHeader data="0100"/> <dataBody> <REQUEST domainType="LOGIN" streamId="1" containerType="NO_DATA" flags="0x04 (STREAMING)" dataSize="0"> <key flags="0x26 (HAS_NAME|HAS_NAME_TYPE|HAS_ATTRIB)" name="GE-A-01641484-3-2729" nameType="1" attribContainerType="ELEMENT_LIST"> <attrib> <elementList flags="0x08 (HAS_STANDARD_DATA)"> <elementEntry name="ApplicationId" dataType="ASCII_STRING" data="256"/> <elementEntry name="ApplicationName" dataType="ASCII_STRING" data="ema"/> <elementEntry name="Position" dataType="ASCII_STRING" data="ppp"/> <elementEntry name="Password" dataType="ASCII_STRING" data="xxx"/> <elementEntry name="Role" dataType="UINT" data="0"/> </elementList> </attrib> </key> <dataBody> </dataBody> </REQUEST> </dataBody> </GENERIC> <!-- Incoming Reactor message --> <!-- java.nio.channels.SocketChannel[connected local=/192.168.1.11:50726 remote=chp02-emea1.thomsonreuters.com/155.46.24.14:443] --> <!-- Wed Feb 12 13:54:31 GMT 2020 --> <!-- rwfMajorVer="14" rwfMinorVer="1" --> <GENERIC domainType="SYSTEM" streamId="3" containerType="NO_DATA" flags="0x11 (HAS_EXTENDED_HEADER|MESSAGE_COMPLETE)" dataSize="0"> <extendedHeader data="0200 0000 0001 0000 000B 71B0"/> <dataBody> </dataBody> </GENERIC> <!-- Incoming Reactor message --> <!-- java.nio.channels.SocketChannel[connected local=/192.168.1.11:50726 remote=chp02-emea1.thomsonreuters.com/155.46.24.14:443] --> <!-- Wed Feb 12 13:54:34 GMT 2020 --> <!-- rwfMajorVer="14" rwfMinorVer="1" --> <GENERIC domainType="SYSTEM" streamId="3" containerType="MSG" flags="0x19 (HAS_EXTENDED_HEADER|HAS_SEQ_NUM|MESSAGE_COMPLETE)" seqNum="1" dataSize="198"> <extendedHeader data="0100"/> <dataBody> <STATUS domainType="LOGIN" streamId="1" containerType="NO_DATA" flags="0xA8 (HAS_MSG_KEY|HAS_STATE|PRIVATE_STREAM)" State: Closed/Suspect/Not entitled - text: "TRCE not configured" dataSize="0"> <key flags="0x26 (HAS_NAME|HAS_NAME_TYPE|HAS_ATTRIB)" name="GE-A-01641484-3-2729" nameType="1" attribContainerType="ELEMENT_LIST"> <attrib> <elementList flags="0x08 (HAS_STANDARD_DATA)"> <elementEntry name="ApplicationId" dataType="ASCII_STRING" data="256"/> <elementEntry name="ApplicationName" dataType="ASCII_STRING" data="ema"/> <elementEntry name="Position" dataType="ASCII_STRING" data="ppp"/> <elementEntry name="Password" dataType="ASCII_STRING" data="xxx"/> <elementEntry name="Role" dataType="UINT" data="0"/> </elementList> </attrib> </key> <dataBody> </dataBody> </STATUS> </dataBody> </GENERIC> 2020-02-12T13:54:34,286 TunnelStreamListener [pool-3-thread-1] INFO : TunnelStreamListener.onAllMsg StatusMsg streamId="5" domain="System Domain" privateStream state="Closed / Suspect / Not entitled / 'TRCE not configured'" name="TUNNEL1" serviceId="10" serviceName="DDS_TRCE" StatusMsgEnd 2020-02-12T13:54:34,286 TunnelStreamListener [pool-3-thread-1] WARN : Tunnel stream went down, will attempt to reconnect if not shutting down 2020-02-12T13:54:34,287 RefinitivDataViewer [pool-3-thread-1] INFO : Connection is DOWN 2020-02-12T13:54:34,287 RefinitivConnector [pool-3-thread-1] INFO : Reconnecting to Refinitiv in 5 seconds
