Error decoding a FieldList's FieldEntry
Can someone please can help? I have a question below. I am encoding a message with following types, a refresh message embedded with element list of field list. When I encode a field entry with string, I get an error when I try to decode the message. The code fails on a call to rsslDecodeFieldEntry.
elektronrefinitiv-realtimeelektron-sdktrepfieldsiteration
When decoding the field list’s entries, use the same iterator you used to decode the field list:
if( ( ret = rsslDecodeFieldList(&decIterFieldlist, &fieldList, 0 ) ) == RSSL_RET_SUCCESS  )
    RsslFieldEntry rsslFieldEntry ;
    ret =   rsslDecodeFieldEntry( &decIterFieldlist, &rsslFieldEntry );
You can also perform encoding and decoding of multiple levels of data with a single iterator, if you wish. For an example, see the rsslEncDecExample application included in UPA releases.
