Source Update message ignored by ADH?
I have a problem with source update messages sent to the ADH from a UPA Java application.
Source refresh messages work fine. If my app publishes a refresh with an "up" status everything is OK.
However, sometimes my app publishes a refresh with a "down" status, followed by an update. (This is caused by the feed that my app is publishing to TREP.)
Here is the refresh:
<!-- rwfMajorVer="14" rwfMinorVer="0" -->
<refreshMsg domainType="RSSL_DMT_SOURCE" streamId="2" containerType="RSSL_DT_MAP" flags="0x68
(RSSL_RFMF_HAS_MSG_KEY|RSSL_RFMF_SOLICITED|RSSL_RFMF_REFRESH_COMPLETE)" groupId="0"
dataState="RSSL_DATA_OK" streamState="RSSL_STREAM_OPEN" code="RSSL_SC_NONE" text="Source Directory
Refresh Completed"  dataSize="218">
    <key  flags="0x8 (RSSL_MKF_HAS_FILTER)"  filter="3"/>
    <dataBody>
        <map flags="0x0" countHint="0" keyPrimitiveType="RSSL_DT_UINT"
containerType="RSSL_DT_FILTER_LIST" >
            <mapEntry flags="0x0" action="RSSL_MPEA_ADD_ENTRY" key="257" >
                <filterList containerType="RSSL_DT_ELEMENT_LIST" countHint="0" flags="0x0">
                    <filterEntry id="1" action="RSSL_FTEA_SET_ENTRY" flags="0x0"
containerType="RSSL_DT_ELEMENT_LIST">
                        <elementList flags="0x8 (RSSL_ELF_HAS_STANDARD_DATA)">
                            <elementEntry name="Name" dataType="RSSL_DT_ASCII_STRING"
data="AUTEX_AT"/>
                            <elementEntry name="Capabilities" dataType="RSSL_DT_ARRAY">
                                <array itemLength="0" primitiveType="RSSL_DT_UINT">
                                    <arrayEntry data="5"/>
                                    <arrayEntry data="4"/>
                                    <arrayEntry data="1"/>
                                </array>
                            </elementEntry>
                            <elementEntry name="DictionariesProvided" dataType="RSSL_DT_ARRAY">
                                <array itemLength="0" primitiveType="RSSL_DT_ASCII_STRING">
                                    <arrayEntry data="FIXFld"/>
                                    <arrayEntry data="FIXEnum"/>
                                </array>
                            </elementEntry>
                            <elementEntry name="DictionariesUsed" dataType="RSSL_DT_ARRAY">
                                </array>
                            </elementEntry>
                        </elementList>
                    </filterEntry>
                    <filterEntry id="2" action="RSSL_FTEA_SET_ENTRY" flags="0x0"
                            <elementEntry name="ServiceState" dataType="RSSL_DT_UINT" data="0"/>
                            <elementEntry name="AcceptingRequests" dataType="RSSL_DT_UINT"
data="0"/>
                            <elementEntry name="Status" dataType="RSSL_DT_STATE"
dataState="RSSL_DATA_SUSPECT" streamState="RSSL_STREAM_CLOSED" code="RSSL_SC_NONE" text="Service
Down" />
                        </elementList>
                    </filterEntry>
                </filterList>
            </mapEntry>
        </map>
    </dataBody>
</refreshMsg
Here is the update:
<updateMsg domainType="RSSL_DMT_SOURCE" streamId="2" containerType="RSSL_DT_MAP" flags="0x80
(RSSL_UPMF_DO_NOT_CONFLATE)" updateType="0" dataSize="74">
    <dataBody>
            <mapEntry flags="0x0" action="RSSL_MPEA_UPDATE_ENTRY" key="257" >
                            <elementEntry name="ServiceState" dataType="RSSL_DT_UINT" data="1"/>
data="1"/>
dataState="RSSL_DATA_OK" streamState="RSSL_STREAM_OPEN" code="RSSL_SC_NONE" text="OK" />
                        </elementList>
                    </filterEntry>
                </filterList>
            </mapEntry>
        </map>
    </dataBody>
</updateMsg>
Any ideas?
elektronrefinitiv-realtimeelektron-sdktrepjavaADHServiceupa
11.3k 25 8 13
To publish service "up" status via source directory update message, provider application needs to encode the info filter entry (i.e. service name, capability) apart from the state filter entry (i.e. ServiceState, AcceptingRequests).
Below is the sample of directory update message for service "up".
    <dataBody>
data="AUTEX_AT"/>
                                </array>
                            </elementEntry>
                                </array>
                            </elementEntry>
                                </array>
                            </elementEntry>
                        </elementList>
                    </filterEntry>
data="1"/>
                        </elementList>
                    </filterEntry>
                </filterList>
            </mapEntry>
        </map>
    </dataBody>
</updateMsg
