Unable to see ANSIPage data in consumer
Running a application which acts as InteractiveProvider using RFA 8. When a consumer connects and request MARKET_PRICE, the data sent as FIELD_LIST shows fine on the consumer but when trying to send the data as ANSIPAGE, the consumer doesn't get the refresh response ( consumer logs show STATUS message with state as SUSPECT and text: "A7: Source did not respond"). Enabled trace on provider and following is the response sent:
---XML TRACE---
<refreshMsg rwfMajorVer="14" rwfMinorVer="1" mType="RWF_MT_MARKET_PRICE" refreshFlags="0x68" dataFormat="RSSL_DF_ANSI_PAGE" streamId="3" groupId="0002" streamState="RSSL_STREAM_OPEN" dataState="RSSL_DATA_OK" code="RSSL_SC_NONE" text="OK" respType="0">
<key flags="0x7" name="23" nameType="1" serviceId="1"/>
<dataBody>
<ansiPage data="[?25l[?7h[m(B)B[02;01H[0;32;40m[>0;4;30;41m1W[0m[>0m [02;20H[0;30;42m[>0;4;30;42m55[0m[>0m [02;26H[0;32;40m[>0;4;30;41m-[0m[>0m [02;50H[0;32;40m[>0;4;30;41m50[0m[>0m [02;54H[0;32;40m[>0;4;30;41m-[0m[>0m [01;01H[2K[01;01H[0;33;44m[>0;4;34;41mIssueName Price Size Close Last [01;01HIssueName [01;25HPrice [01;50HSize [01;60HClose [01;70HLast [>0m "/>
</dataBody>
</refreshMsg>
---DATA TRACE---
MESSAGE
Msg Type: MsgType.REFRESH_RESP
Msg Model Type: MARKET_PRICE
Indication Flags: REFRESH_COMPLETE
Hint Flags: HAS_ATTRIB_INFO | HAS_ITEM_GROUP | HAS_RESP_TYPE_NUM | HAS_STATE
Stream Id: 3
State: OPEN, OK, NONE, "OK"
Group: 0002
RespTypeNum: 0(REFRESH_SOLICITED)
AttribInfo
ServiceId: 1
NameType: 1 (RIC)
Payload: 435 bytes
Hex Format and Data Bytes:
00000 1b 5b 3f 32 35 6c 1b 5b--3f 37 68 1b 5b 6d 1b 28 |.[?25l.[-?7h.[m.(|
00010 42 1b 29 42 1b 5b 30 32--3b 30 31 48 0f 1b 5b 30 |B.)B.[02-;01H..[0|
00020 3b 33 32 3b 34 30 6d 1b--5b 3e 30 3b 34 3b 33 30 |;32;40m.-[>0;4;30|
00030 3b 34 |;4 |
Hex Format:
1b5b3f32356c1b5b3f37681b5b6d1b28
421b29421b5b30323b3031480f1b5b30
3b33323b34306d1b5b3e303b343b3330
3b34316d31571b5b306d1b5b3e306d20
1b5b30323b3230481b5b303b33303b34
326d1b5b3e303b343b33303b34326d35
351b5b306d1b5b3e306d201b5b30323b
3236481b5b303b33323b34306d1b5b3e
303b343b33303b34316d2d1b5b306d1b
5b3e306d201b5b30323b3530481b5b30
3b34316d35301b5b306d1b5b3e306d20
1b5b30323b3534481b5b303b33323b34
306d1b5b3e303b343b33303b34316d2d
1b5b306d1b5b3e306d201b5b30313b30
31481b5b324b1b5b30313b3031481b5b
303b33333b34346d1b5b3e303b343b33
343b34316d49737375654e616d652020
20202020202020202020202020507269
63652020202020202020202020202020
20202020202053697a65202020202020
436c6f736520202020204c6173742020
20202020201b5b30313b303148497373
75654e616d65201b5b30313b32354850
72696365201b5b30313b35304853697a
65201b5b30313b363048436c6f736520
1b5b30313b3730484c617374201b5b3e
306d00
Data Bytes:
Can someone clarify as to why the above message doesn't show up on the consumer end. Also is there a difference between RSSL_DF_ANSI_PAGE and RSSL_DT_ANSI_PAGE
Please let me know if any more information is required.
elektronrefinitiv-realtimetrepansi
Hi @narendranb
Please include full trace of the Request message and full trace of the response Status Msg for completeness.
In terms of RSSL_DF and RSSL_DT - DF specifies DataFormat and DT specifies DataType
As far as I am aware RSSL_DT_ANSI_PAGE is a DataType
DataFormat is the container type e.g.Map, ElementList etc
DataType is the encoding type e.g. UInt,AsciiString, Real, Float, AnsiPage etc.
