issues with Elektron-SDK C/C++ Build
while running $cmake -HElektronSDK -Bbuild-esdk -DCMAKE_BUILD_TYPE=Debug the following error occurs.
CMake Error at /mnt/c/Users/u6079328/OneDrive - Refinitiv/Fuzzing/build-esdk/external/BUILD/elektron-sdk-binarypack/build/elektron-sdk-binarypack-prefix/src/elektron-sdk-binarypack-stamp/extract-elektron-sdk-binarypack.cmake:26 (execute_process):
execute_process given unknown argument "-".
CMakeFiles/elektron-sdk-binarypack.dir/build.make:90: recipe for target 'elektron-sdk-binarypack-prefix/src/elektron-sdk-binarypack-stamp/elektron-sdk-binarypack-download' failed
make[2]: *** [elektron-sdk-binarypack-prefix/src/elektron-sdk-binarypack-stamp/elektron-sdk-binarypack-download] Error 1
CMakeFiles/Makefile2:75: recipe for target 'CMakeFiles/elektron-sdk-binarypack.dir/all' failed
make[1]: *** [CMakeFiles/elektron-sdk-binarypack.dir/all] Error 2
Makefile:83: recipe for target 'all' failed
make: *** [all] Error 2
CMake Error at CMake/rcdevExternalUtils.cmake:189 (message):
External Project Build step for elektron-sdk-binarypack in
Refinitiv/Fuzzing/build-esdk/external/BUILD/elektron-sdk-binarypack failed:
2
Call Stack (most recent call first):
CMake/addExternal_elektron-sdk-binarypack.cmake:120 (rcdev_config_build_ep)
CMakeLists.txt:24 (include)
-- Configuring incomplete, errors occurred!
See also "/mnt/c/Users/u6079328/OneDrive - Refinitiv/Fuzzing/build-esdk/CMakeFiles/CMakeOutput.log".
How can this be solved?
I followed the error mentioned at the beginning and removed the unknown argument mentioned. This didnt seem to solve the problem.
the elektron sdk binarypack is already downloaded as well within the same directory. Why isnt the build able to detect that? As it still tries download a binary pack and unzip it.
elektronrefinitiv-realtimeelektron-sdkerrorbuildissue
@Kristiyan.Ohotski
I used the steps shown in this docker file and it works fine.
sh-4.2# pwd
/opt/refinitiv
sh-4.2# ls
Elektron-SDK  cmake-3.11.2-Linux-x86_64         libxml2-2.9.9.tar.gz
cmake-3.11.2-Linux-x86_64.tar.gz
sh-4.2# cd Elektron-SDK/
sh-4.2# ls
CMake           Elektron API Entity Contributor License Agreement.pdf      Java        esdk
CMakeLists.txt  Elektron API Individual Contributor License Agreement.pdf  LICENSE.md
Cpp-C           Elektron-SDK-BinaryPack                                    README.md
sh-4.2# cd ..
sh-4.2# pwd
/opt/refinitiv
sh-4.2# cmake -HElektron-SDK -Bbuild-esdk -DCMAKE_BUILD_TYPE=Debug
Elektron-SDK-BinaryPack is under the Elektron-SDK directory.
Thanks for the answer, seems like my directories got mixed up
23k 22 9 14
Hello @Kristiyan.Ohotski,
You are building Elektron SDK C/C++ from code, via cmake, and I do not see included in the command line a platform-specific target for the build, which results in not being built.
Have you had a chance to review Elektron SDK Installation Guide, that comes with SDK within Cpp-C\Eta\Docs folder?
Depending on the platform, something like the following should work from the top level of the SDK download:
cmake -G "Visual Studio 16 2019" -A x64
You may wish to include other, optional parameters.
Once the overall build succeeds, you may wish to build other targets, specific to projects included within SDK, please see more on targets in ESDK Installation Guide's section Targets.
