Last week we have received a lot of socket exceptions. The issue is instead of sending success (200 return code) or failure response (202 or other return code), Refinitiv throwed SocketException.
Can you please let us know the reason for the socket exception instead of proper response?
The socket is not closed from our end.
Stacktrace is given below. We use Java for our programming.
---------------------------------------------------------------------------------------------------------------------------------------: org.springframework.web.client.ResourceAccessException: I/O error on POST request for "https://hosted.datascopeapi.reuters.com/RestApi/v1/Authentication/RequestToken":Unexpected end of file from server; nested exception is java.net.SocketException: Unexpected end of file from server
at org.springframework.web.client.RestTemplate.doExecute(RestTemplate.java:580) [spring-web-4.1.6.RELEASE.jar:4.1.6.RELEASE]
at org.springframework.web.client.RestTemplate.execute(RestTemplate.java:530) [spring-web-4.1.6.RELEASE.jar:4.1.6.RELEASE]
at org.springframework.web.client.RestTemplate.postForObject(RestTemplate.java:330) [spring-web-4.1.6.RELEASE.jar:4.1.6.RELEASE]
at com.eurex.bia.refinitiv.service.impl.RefinitivServiceImpl.fetchInstrumentPrice(RefinitivServiceImpl.java:101) [classes:]
at com.eurex.bia.refinitiv.listener.RefinitivAdhocListener.processAdhocPriceRequest(RefinitivAdhocListener.java:72) [classes:]
at com.eurex.bia.refinitiv.listener.RefinitivAdhocListener$$FastClassBySpringCGLIB$$53f7677f.invoke(<generated>) [spring-core-4.1.6.RELEASE.jar:]
at org.springframework.cglib.proxy.MethodProxy.invoke(MethodProxy.java:204) [spring-core-4.1.6.RELEASE.jar:4.1.6.RELEASE]
at org.springframework.aop.framework.CglibAopProxy$CglibMethodInvocation.invokeJoinpoint(CglibAopProxy.java:717) [spring-aop-4.1.6.RELEASE.jar:4.1.6.RELEASE]
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:157) [spring-aop-4.1.6.RELEASE.jar:4.1.6.RELEASE]
at org.springframework.transaction.interceptor.TransactionInterceptor$1.proceedWithInvocation(TransactionInterceptor.java:99) [spring-tx-4.1.6.RELEASE.jar:4.1.6.RELEASE]
at org.springframework.transaction.interceptor.TransactionAspectSupport.invokeWithinTransaction(TransactionAspectSupport.java:281) [spring-tx-4.1.6.RELEASE.jar:4.1.6.RELEASE]
at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:96) [spring-tx-4.1.6.RELEASE.jar:4.1.6.RELEASE]
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179) [spring-aop-4.1.6.RELEASE.jar:4.1.6.RELEASE]
at org.springframework.aop.framework.CglibAopProxy$DynamicAdvisedInterceptor.intercept(CglibAopProxy.java:653) [spring-aop-4.1.6.RELEASE.jar:4.1.6.RELEASE]
at com.eurex.bia.refinitiv.listener.RefinitivAdhocListener$$EnhancerBySpringCGLIB$$7ca48134.processAdhocPriceRequest(<generated>) [spring-core-4.1.6.RELEASE.jar:]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) [rt.jar:1.8.0_222]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) [rt.jar:1.8.0_222]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) [rt.jar:1.8.0_222]
at java.lang.reflect.Method.invoke(Method.java:498) [rt.jar:1.8.0_222]
at org.apache.camel.component.bean.MethodInfo.invoke(MethodInfo.java:408) [camel-core-2.15.1.redhat-621084.jar:2.15.1.redhat-621084]
at org.apache.camel.component.bean.MethodInfo$1.doProceed(MethodInfo.java:279) [camel-core-2.15.1.redhat-621084.jar:2.15.1.redhat-621084]
at org.apache.camel.component.bean.MethodInfo$1.proceed(MethodInfo.java:252) [camel-core-2.15.1.redhat-621084.jar:2.15.1.redhat-621084]
at org.apache.camel.component.bean.BeanProcessor.process(BeanProcessor.java:171) [camel-core-2.15.1.redhat-621084.jar:2.15.1.redhat-621084]
at org.apache.camel.util.AsyncProcessorHelper.process(AsyncProcessorHelper.java:109) [camel-core-2.15.1.redhat-621084.jar:2.15.1.redhat-621084]
at org.apache.camel.component.bean.BeanProcessor.process(BeanProcessor.java:68) [camel-core-2.15.1.redhat-621084.jar:2.15.1.redhat-621084]
at org.apache.camel.component.bean.BeanProducer.process(BeanProducer.java:38) [camel-core-2.15.1.redhat-621084.jar:2.15.1.redhat-621084]
at org.apache.camel.processor.SendProcessor.process(SendProcessor.java:139) [camel-core-2.15.1.redhat-621084.jar:2.15.1.redhat-621084]
at org.apache.camel.management.InstrumentationProcessor.process(InstrumentationProcessor.java:77) [camel-core-2.15.1.redhat-621084.jar:2.15.1.redhat-621084]
at org.apache.camel.processor.RedeliveryErrorHandler.process(RedeliveryErrorHandler.java:448) [camel-core-2.15.1.redhat-621084.jar:2.15.1.redhat-621084]
at org.apache.camel.processor.CamelInternalProcessor.process(CamelInternalProcessor.java:191) [camel-core-2.15.1.redhat-621084.jar:2.15.1.redhat-621084]
at org.apache.camel.processor.Pipeline.process(Pipeline.java:121) [camel-core-2.15.1.redhat-621084.jar:2.15.1.redhat-621084]
at org.apache.camel.processor.Pipeline.process(Pipeline.java:83) [camel-core-2.15.1.redhat-621084.jar:2.15.1.redhat-621084]
at org.apache.camel.processor.DelegateAsyncProcessor.process(DelegateAsyncProcessor.java:87) [camel-core-2.15.1.redhat-621084.jar:2.15.1.redhat-621084]
at org.apache.camel.component.jms.EndpointMessageListener.onMessage(EndpointMessageListener.java:103) [camel-jms-2.15.1.redhat-621084.jar:2.15.1.redhat-621084]
at org.springframework.jms.listener.AbstractMessageListenerContainer.doInvokeListener(AbstractMessageListenerContainer.java:699) [spring-jms-4.1.6.RELEASE.jar:4.1.6.RELEASE]
at org.springframework.jms.listener.AbstractMessageListenerContainer.invokeListener(AbstractMessageListenerContainer.java:637) [spring-jms-4.1.6.RELEASE.jar:4.1.6.RELEASE]
at org.springframework.jms.listener.AbstractMessageListenerContainer.doExecuteListener(AbstractMessageListenerContainer.java:605) [spring-jms-4.1.6.RELEASE.jar:4.1.6.RELEASE]
at org.springframework.jms.listener.AbstractPollingMessageListenerContainer.doReceiveAndExecute(AbstractPollingMessageListenerContainer.java:308) [spring-jms-4.1.6.RELEASE.jar:4.1.6.RELEASE]
at org.springframework.jms.listener.AbstractPollingMessageListenerContainer.receiveAndExecute(AbstractPollingMessageListenerContainer.java:246) [spring-jms-4.1.6.RELEASE.jar:4.1.6.RELEASE]
at org.springframework.jms.listener.DefaultMessageListenerContainer$AsyncMessageListenerInvoker.invokeListener(DefaultMessageListenerContainer.java:1144) [spring-jms-4.1.6.RELEASE.jar:4.1.6.RELEASE]
at org.springframework.jms.listener.DefaultMessageListenerContainer$AsyncMessageListenerInvoker.executeOngoingLoop(DefaultMessageListenerContainer.java:1136) [spring-jms-4.1.6.RELEASE.jar:4.1.6.RELEASE]
at org.springframework.jms.listener.DefaultMessageListenerContainer$AsyncMessageListenerInvoker.run(DefaultMessageListenerContainer.java:1033) [spring-jms-4.1.6.RELEASE.jar:4.1.6.RELEASE]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [rt.jar:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [rt.jar:1.8.0_222]
at java.lang.Thread.run(Thread.java:748) [rt.jar:1.8.0_222]
Caused by: java.net.SocketException: Unexpected end of file from server
at sun.net.www.http.HttpClient.parseHTTPHeader(HttpClient.java:851) [rt.jar:1.8.0_222]
at sun.net.www.http.HttpClient.parseHTTP(HttpClient.java:678) [rt.jar:1.8.0_222]
at sun.net.www.protocol.http.HttpURLConnection.doTunneling(HttpURLConnection.java:2061) [rt.jar:1.8.0_222]
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:183) [rt.jar:1.8.0_222]
at sun.net.www.protocol.https.HttpsURLConnectionImpl.connect(HttpsURLConnectionImpl.java:167) [rt.jar:1.8.0_222]
at org.springframework.http.client.SimpleBufferingClientHttpRequest.executeInternal(SimpleBufferingClientHttpRequest.java:81) [spring-web-4.1.6.RELEASE.jar:4.1.6.RELEASE]
at org.springframework.http.client.AbstractBufferingClientHttpRequest.executeInternal(AbstractBufferingClientHttpRequest.java:48) [spring-web-4.1.6.RELEASE.jar:4.1.6.RELEASE]
at org.springframework.http.client.AbstractClientHttpRequest.execute(AbstractClientHttpRequest.java:53) [spring-web-4.1.6.RELEASE.jar:4.1.6.RELEASE]
at org.springframework.web.client.RestTemplate.doExecute(RestTemplate.java:569) [spring-web-4.1.6.RELEASE.jar:4.1.6.RELEASE]
... 46 more
