Backend Error Failed to Deserialize backend Response
I am facing the same problem as mentioned in this thread. https://community.developers.refinitiv.com/questions/29948/eikon-data-api-backend-error-failed-to-deserialize.html
@pierre.faurel suggestion to use single quotes ' ' does not generate errors but the response is empty unlike the NEWS monitor app in EIKON desktop application.
It is also surprising the high quality EIKON tutorial series uses below syntax which is also generate errors. https://developers.refinitiv.com/eikon-apis/eikon-data-api/learning?content=15351&type=learning_material_item
q = "Product:IFREM AND Topic:ISU AND Topic:EUB AND (\"PRICED\" OR \"DEAL\")"
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonerrornews
@vijay.shah
Yes, you are correct. The code in the tutorial returns an error. I will contact the product team to verify it.
The solution that I can think of is using the triple backslashes to escape the double-quotes.
from datetime import date
start_date, end_date = date(2016, 1, 1), date.today()
q = "Product:IFREM AND Topic:ISU AND Topic:EUB AND (\\\"PRICED\\\" OR \\\"DEAL\\\")"
headlines = ek.get_news_headlines(query=q, date_from=start_date, date_to=end_date, count=100)
headlines.head()
@jirapongse.phuriphanvichai,
This works fine, thanks for quick response. I found below syntax is slightly more concise and also works without errors...
q = r'Product:IFREM AND Topic:ISU AND Topic:EUB AND (\"PRICED\" OR \"DEAL\")'
13.7k 26 8 12
@vijay.shah, @jirapongse.phuriphanvichai,
The following is even simpler, and works fine (tested in a Python Notebook, the result is not empty):
q = 'Product:IFREM AND Topic:ISU AND Topic:EUB AND (PRICED: OR DEAL:)'
@Christiaan Meihsl very cool, did not know this is allowed.
