Problem with get a news through api key for python and Web Eikon
Hello!
In python error is
"Error on checking port 9000, Error on checking port 36036, Error on handshake port None : Failed to parse: localhost:None Port number was not identified. Check if Eikon Desktop or Eikon API Proxy is running".
How I can to use api key for python? How i can to get a news (headlines and urls) from Eikon web?
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonerrornews
@miha-css
To use Eikon Data APIs (Python) to retrieve data, you need to have Eikon Desktop or Eikon Data API Proxy installed on the machine. Then, you need to run Eikon Desktop or Eikon Data API Proxy.
For more information, please refer to Eikon Data API(Python) Troubleshooting.
For the error in the Eikon web, please directly contact the Eikon support team to verify the problem.
11.5k 16 7 10
Hello @miha-css
You can get the App Key via the following ways:
  1. In the Eikon Desktop application, go to the Search Bar and type "APP KEY" , then select the App Key Generator
  2. Via AppKey Generator web site.
