Unable to import DatastreamDSWS
Traceback (most recent call last):
File "getPythonData.py", line 13, in <module>
import DatastreamDSWS as dsws
File "/home/ubuntu/.local/lib/python3.5/site-packages/DatastreamDSWS/__init__.py", line 11, in <module>
from .DS_Response import Datastream
File "/home/ubuntu/.local/lib/python3.5/site-packages/DatastreamDSWS/DS_Response.py", line 9, in <module>
import pandas as pd
File "/home/ubuntu/.local/lib/python3.5/site-packages/pandas/__init__.py", line 55, in <module>
from pandas.core.api import (
File "/home/ubuntu/.local/lib/python3.5/site-packages/pandas/core/api.py", line 5, in <module>
from pandas.core.arrays.integer import (
File "/home/ubuntu/.local/lib/python3.5/site-packages/pandas/core/arrays/__init__.py", line 1, in <module>
from .array_ import array # noqa: F401
File "/home/ubuntu/.local/lib/python3.5/site-packages/pandas/core/arrays/array_.py", line 7, in <module>
from pandas.core.dtypes.common import (
File "/home/ubuntu/.local/lib/python3.5/site-packages/pandas/core/dtypes/common.py", line 11, in <module>
from pandas.core.dtypes.dtypes import (
File "/home/ubuntu/.local/lib/python3.5/site-packages/pandas/core/dtypes/dtypes.py", line 53, in <module>
class Registry:
File "/home/ubuntu/.local/lib/python3.5/site-packages/pandas/core/dtypes/dtypes.py", line 84, in Registry
self, dtype: Union[Type[ExtensionDtype], str]
File "/usr/lib/python3.5/typing.py", line 552, in __getitem__
dict(self.__dict__), parameters, _root=True)
File "/usr/lib/python3.5/typing.py", line 512, in __new__
for t2 in all_params - {t1} if not isinstance(t2, TypeVar)):
File "/usr/lib/python3.5/typing.py", line 512, in <genexpr>
File "/usr/lib/python3.5/typing.py", line 1077, in __subclasscheck__
if super().__subclasscheck__(cls):
File "/usr/lib/python3.5/abc.py", line 225, in __subclasscheck__
for scls in cls.__subclasses__():
TypeError: descriptor '__subclasses__' of 'type' object needs an argument
datastream-apidsws-api
Hello @abbanerjee
Thank you for your participation in the forum. Is the reply below satisfactory in resolving your query?
If so please can you click the 'Accept' text next to the appropriate reply. This will guide all community members who have a similar question.
Thanks,
AHS
11.5k 16 7 10
Hello @abbanerjee
Based a the given stack trace, I assume that you are using Python version 3.5.x.
Please note that DatastreamDSWS for Python supports Python version 3.6 and above. (see "Requirement" section in Getting Start with Python document). I suggest you upgrade the Python version that run Datastream application.
I can replicate the same kind of error messages with Python 3.5.6. If I change to newer version, I did not encounter the problem.
