http://product.datastream.com is no accessible when used to fetch data from Eviews10. Do you know why and a solution? My querry ID with Refinitive case is : 08171566
datastream-apidsws-api
11.3k 25 8 13
According to the case: 08171566, the issue has been solved by setting up the network proxy server in order for the page to load with no issues on their end.
11.5k 16 7 10
Hello @Dinoj
I believe the support team has give you updates via the case 08171566. Does the problem still persist? Did you contact EViews support yet?
