EMA API Reissue not working
Hi Refinitiv Support,
I have a use case where I open a streaming request for an item with 2 fields. After some time, I add 2 more fields to the item and invoke reissue on the consumer passing in the original item handle. The reissue is getting ignored as I still continue to receive only the initial 2 fields. I debuged and observed that the reissue request is throwing "reissue not allowed on an openstream" exception.
I checked the user guide and it appears you can invoke reissue this way without explicitly closing the stream.
Any idea what am doing wrong? Am using Java.
Regards,
josa
Hi @Wasin Waeosri,
This is working now after I upgraded from version 3.2.0.1 to 3.3.0.1. Please close the ticket.
Regards,
josa
11.5k 16 7 10
Hello @josa
I did a quick test with EMA Java 3.4.0 (ESDK - Java 1.4.0) example360_MarketPrice_View example application. The example can send a reissue request and receive new set of fields successfully.
My main Consumer.java function:
AppClient appClient = new AppClient();
consumer  = EmaFactory.createOmmConsumer(EmaFactory.createOmmConsumerConfig().host("172.20.33.30:14002").username("user"));
appClient.setOmmConsumer(consumer);
ElementList view = EmaFactory.createElementList();
OmmArray array = EmaFactory.createOmmArray();
array.fixedWidth(2);
array.add(EmaFactory.createOmmArrayEntry().intValue(22)); //BID
array.add(EmaFactory.createOmmArrayEntry().intValue(25)); //ASK
view.add(EmaFactory.createElementEntry().uintValue(EmaRdm.ENAME_VIEW_TYPE, 1));
view.add(EmaFactory.createElementEntry().array(EmaRdm.ENAME_VIEW_DATA, array));
consumer.registerClient(EmaFactory.createReqMsg().serviceName("ELEKTRON_AD").name("/EUR=").payload(view), appClient);
My AppClient class:
public void onRefreshMsg(RefreshMsg refreshMsg, OmmConsumerEvent event){
if (refreshMsg.state().streamState() == OmmState.StreamState.OPEN && refreshMsg.state().dataState() == OmmState.DataState.OK && !hasFirstRefresh ){
   System.out.println("Receive First Refresh!!");
   array.add(EmaFactory.createOmmArrayEntry().intValue(15)); //CURRENCY
   array.add(EmaFactory.createOmmArrayEntry().intValue(11)); //NETCHNG_1
   _ommConsumer.reissue(EmaFactory.createReqMsg().serviceName("ELEKTRON_AD").name("IBM.N").payload(view), event.handle());
   System.out.println("Reissue Sent!!!");
   hasFirstRefresh = true;
Result:
Item Name: /EUR=
Service Name: ELEKTRON_AD
Item State: Open / Ok / None / 'All is well'
Fid: 22 Name = BID DataType: Real Value: 1.1009
Fid: 25 Name = ASK DataType: Real Value: 1.1013
Reissue Sent!!!
Item Name: /EUR=
Fid: 11 Name = NETCHNG_1 DataType: Real Value: 0.0011
Fid: 15 Name = CURRENCY DataType: Enum Value: USD
Could you please share your EMA Java version, you reissue source code and the XML trace file when the problem occurs?
You can enable the EMA Java trace messages by setting <XmlTraceToStdout value="1"/> in the EmaConfig.xml file.
