I have next error: Could not create session _Default::RSSLSession
rfa.sessionName=_Default::RSSLSession
this error is in QA, where sessionName is open becouse personal reuters thomsom give it's a configuration.
Hello @dcruzf84
Did you populate the _Default session configuration to the Java configuration database yet?
You can use RFA Java config_loader (command line) or config_editor tool (GUI) to populate the configurations to Java configuration database.
The tools are available at <RFA Java package>/Tools folder.
