How to set real FIDs to blank using Java EMA?
I'm looking for an example on setting a field to blank using the EMA API
Current Java EMA code to set FIDs with no logic to set real FIDs to blank
FieldList nestedFieldList = EmaFactory.createFieldList();
nestedFieldList.add(createOmmRealField(22, priceInfo.getBidPrice()));
public static FieldEntry createOmmRealField(int fieldId, BigDecimal value) {
BigDecimal valueStripped = value;//value.stripTrailingZeros();
// magnitude constants for scale exists up to -7
if(valueStripped.scale() < -7) {
valueStripped = valueStripped.setScale(-7);
// we translate scale to Magnitude type constant
int magnitude = OmmReal.MagnitudeType.EXPONENT_0 - valueStripped.scale();
long mantissa = valueStripped.unscaledValue().longValueExact();
return EmaFactory.createFieldEntry().real(fieldId, mantissa, magnitude);
ETA version of setting blank:
// ASK
fieldEntry.clear();
dictionaryEntry = dictionary.entry(MarketPriceItem.ASK_FID);
if (dictionaryEntry != null) {
fieldEntry.fieldId(MarketPriceItem.ASK_FID);
fieldEntry.dataType(dictionaryEntry.rwfType());
tempReal.clear();
// Set blank for empty book and wipes
if(mpItem.ASK == -0.0) {
tempReal.blank();
else {
tempReal.value(mpItem.ASK, RealHints.EXPONENT_4);
ret = fieldEntry.encode(encodeIter, tempReal);
if (ret < CodecReturnCodes.SUCCESS) {
return ret;
Hi @Paul.Wuethrich2
Have you tried the following:
EmaFactory.createFieldEntry().codeReal( <fieldID> )
If you refer to the EMA Java documentation for FieldEntry you will note a set of methods such as codeReal, codeInt, codeFloat for adding a blank data code to a field entry
Thanks!
Which doc are you referring to as I checked the following pdfs
EMAJ_DevGuide
EMAJ_RDMUsageGuide
ETAJ_ValueAddDevGuide
API_ConceptsGuide
Just found it by navigating from your starting link:
https://docs-developers.refinitiv.com/1573832247683/6066/Docs/refman/emajava/index.html
Thanks again
Hi @Paul.Wuethrich2
I am referring to the EMA Java Reference guide - which details all the packages/classes/methods etc.
If you are logged into the portal before you click the link in my previous post, it should take you to the right online page.
You should also find it in the following folder of your local Elektron SDK installation
<ESDK Root>\Java\Ema\Docs\refman\emajava\index.html
Thx - looks like I need to pull the latest version of the SDK as mine is from April 2019 and there's no refman/ sub-dir
