Exception:org.apache.http.conn.HttpHostConnectException: Connection to https://hosted.datascopeapi.reuters.com refused
client has generated Token using SOAP API, but not able to connect to Java, he is getting error message
public void getSessionToken(String username, String password) {
try {
HttpPost httppost = new HttpPost("https://hosted.datascopeapi.reuters.com/RestApi/v1/Authentication/RequestToken");
httppost.addHeader("content-type", "application/json; charset=UTF-8");
/*JSONObject TokenRequest = new JSONObject()
.put("Credentials", new JSONObject()
.put("Username", username)
.put("Password", password));*/
StringEntity requestBody = new StringEntity("{\"Credentials\": {\"Username\":\"XXXXXXXXX\",\"Password\":\"XXXXXXX\"}}");
httppost.setEntity(requestBody);
ResponseHandler<String> responseHandler = new BasicResponseHandler();
String response = httpclient.execute(httppost, responseHandler);
//JSONObject jsonResponse = new JSONObject(response);
//sessionToken = jsonResponse.get("value").toString();
System.out.println("Session Token (expires in 24 hours):\n" + response);
} catch (UnsupportedEncodingException e) {
e.printStackTrace();
} catch (ClientProtocolException e) {
} catch (IOException e) {
}sss
… Exception:
at org.apache.http.impl.conn.DefaultClientConnectionOperator.openConnection(DefaultClientConnectionOperator.java:190)
at org.apache.http.impl.conn.ManagedClientConnectionImpl.open(ManagedClientConnectionImpl.java:294)
at org.apache.http.impl.client.DefaultRequestDirector.tryConnect(DefaultRequestDirector.java:645)
at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:480)
dss-rest-apidatascope-selectdssconnection-error
23k 22 9 14
Hello @Prathibha.Mariyappa,
Is the client per chance behind a firewall?
That would be the most common reason, why the connection is refused.
If that is the case, try our Java example that includes proxy handling (DSS2TokenProxy, DSS2TokenPorxyAuth, depending if the proxy requires a proxy username and password spec) , it shows how to specify the proxy to interact with DSS from behind the firewall.
