RFA8.0 in suse platform
1, Can we do the test for user in suse linux or it's only can be tested by user .
2,If user requires to use suse platform can we do the developing work or testing for it .
elektronrefinitiv-realtimetreprfalinux
9.7k 49 38 60
Hi @cheng.yang,
If the client is planning on running an RFA 8 application in Suse, this will not be supported and may likely not work. There are likely no plans to port RFA 8 to Suse. The only supported API according to the compatibility matrix is RFA 7.6.
