.NET Data API FSharp error
I am using .net data api requiring DEEDLE and FSharp/etc from
https://github.com/Refinitiv-API-Samples/Article.EikonDataAPI.DotNet.Library
I get the following error although I do have reference to FSharp.Core
Any suggestions?
Error Loading basket
Could not load file or assembly 'FSharp.Core, Version=4.4.3.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. Strong name validation failed. (Exception from HRESULT: 0x8013141A)
OK
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpython.net
@newuser
After building the application, there is an FSharp.Core.dll file in the built folder. Please also copy this file to the same directory of the application on another machine.
From my test, it works fine with .NET Framework 4.6.1. The platform must be x64.
The version of FSharp.Core is 4.5.0.0.
Have you tried to add the missing reference? Install FSharp by Managing the Nuget Package. Hope this helps.
I am running fine in my box. however, when I copy executables it won't work on another machine.
