No data events from RIC XAU= and XAU=ALL
I've tried to subscribe using a C# program for 'XAU=' or 'XAU=ALL'. No data was returned from server. If I subscribe to currency such as HKDSGD=R, there were data streaming in.
I'm curious why XAU= or XAU=ALL doesn't work.
The fields I subscribed to were ("BID", "ASK", "CTBTR_1", "CTB_LOC1", "BCKGRNDPAG", "DSPLY_NAME", "TIMACT")
In fact my setup is a Thompson Reuters Hosted mode. The C# program interacts with the Eikon desktop software.
ANy clue of why this happens may help a lot. Did I miss out anything?
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpython.net
Hi @Alex Putkov. I have not resolve this issue. Only worked around it. My workaround is not a solution but for temporary measure until I could spend a bit more time on this matter.
I could subscribe and rates with XAUMYR=R
Then I reconvert it back to USD/oz with MYR= rates.
Is not accurate but I'm still preplexed by the cause of getting XAU= rates via C# .API
4.6k 26 7 22
@cewong Assuming you are using .NET Data API, I would suggest subscribing to OnStatusChange and OnError events to determine why do you not get XAU=:
private void Subscribe()
    var realtime = DataServices.Instance.Realtime;
    _subscription = realtime.SetupDataSubscription()
            .WithRics(“EUR=“, “GBP=“)
            .WithFields(“BID”, “ASK”)
            .OnDataUpdated(DataReceivedCallback)
            .OnStatusUpdated(StatusUpdatesCallback)
            .OnError(ErrorCallback) //error call back
            .CreateAndStart();
Here is the list of statuses for your reference.
In addition to the response by @Zhenya Kovalyov, it's worth checking if you can display these RICs in a Quote app in Eikon.
Ok. I'll try that. Will update progress after. Thank you.
@Zhenya Kovalyov - I made the addition as per your suggestion. The response I got for both SetupDataRequest & SetupDataSubscription was 'Ok'.
Code snippet looks like this,
@Alex Putkov. - Yes I get data update Quote App but not from the .NET API. This anomaly occurs only for XAU= and XAU=ALL. If I subscribe to currency such as EUR or AUD, there are data.
Note: Ignore the Elapsed Event heartbeat.
4.6k 26 7 22
@cewong if you are using the standard example, please make sure that DataReceived looks at the correct keys in the update event:
private void DataReceivedCallback(IRealtimeUpdateDictionary updates)
            if (updates.ContainsKey("XAU="))
                if (updates["XAU="].ContainsKey("BID"))
                    Console.WriteLine("XAU=(BID) {0}", updates["XAU="]["BID"].Value.ToString());
                    subscription.Stop();
                    Program.StopMessagePump();
Might that be the case?
@Zhenya Kovalyov yes, in fact, my code just display any keys subscribed. As long as there is an event from EIkon's service, I should be able to show. Unfortunately, that wasn't the case.
@cewong
Were you able to resolve the issue? I'm afraid I'm out of suggestions. The fact that the issue is only happening for a couple of RICs and that you can view these RICs in a Quote app in Eikon makes no sense to me. If indeed you found the root cause of the problem, I'd very much appreciate you sharing it on this thread.
Hi @Alex Putkov. & @Zhenya Kovalyov
An update. I noticed for RIC XAU= is from Commodity but XAUSGD=R is from FX.
1) Is there a difference in subscribing via .NET API for commodity versus Foreign Exchange (FX)?
2) How do I check if my subscription has access via API to Commodity RIC?
Thanks.
@cewong
1. Not really
2. If you do not have access to a ric, it will return a NotPermission error
Is the XAUSGD=R (Thompson Reuters Calculated) rates derived from XAU= (cash spot) x SGD= (local intrabank fx) ?
Another example for rates from XAUEUR=R is from cross of XAU= & EUR=?
@cewong yes, =R usually means 'derived calculation'.
