Intermittent Worldcheckone server connection issue
2% to 3% of total portal worldcheckone call/requests are getting failed with below connection issues to dev worldcheckone server
  • Unable to connect to the remote server
  • The underlying connection was closed: An unexpected error occurred on a receive.
  • The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
  • The remote server returned an error: (503) Server Unavailable.
  • The remote server returned an error: (400) Bad Request.
Is there any known solution for this type of connection issues?
Below is the sample code snippet for call/request
string date = dateValue.ToString("R"); // WC1 header requires GMT datetime stamp
string requestendpoint = "https://" + GateWayHost + GateWayUrl + "cases/" + CaseSystemID + "/screeningRequest";
string postData = "{\"customFields\":[],\"providerTypes\":[\"WATCHLIST\"]}";
string msg = postData;
string dataToSign = "(request-target): post " + GateWayUrl + "cases/" + CaseSystemID + "/screeningRequest" + "\n" +
"host: " + GateWayHost + "\n" + // no https only the host name
"date: " + date;
string hmac = generateAuthHeader(dataToSign, APISecret);
string authorisation = "Signature keyId=\"" + APIKey + "\",algorithm=\"hmac-sha256\",headers=\"(request-target) host date\",signature=\"" + hmac + "\"";
//Defining TLS
ServicePointManager.Expect100Continue = true;
ServicePointManager.SecurityProtocol = SecurityProtocolType.Tls
| SecurityProtocolType.Tls11
| SecurityProtocolType.Tls12
| SecurityProtocolType.Ssl3;
//END
// Send the Request to the API server
HttpWebRequest WebReq = (HttpWebRequest)WebRequest.Create(requestendpoint);
// Set the Headers
WebReq.Method = "POST";
WebReq.Headers.Add("Authorization", authorisation);
WebReq.Headers.Add("Cache-Control", "no-cache");
WebReq.Date = dateValue; // use datetime value GMT time
using (HttpWebResponse WebResp = (HttpWebResponse)WebReq.GetResponse())
{ // Status information about the request
if (WebResp.StatusCode.ToString() == "Created")
str = WC1CaseAuditEventRequest(requestObj, request, calledBy, quoteId, historyId, partyType, CaseSystemID, dateValue);
world-checkworld-check-oneconnection
4.2k 7 5 6
@vijay.shejawal
Thank you for clarifying that you are using the API call "SEQ-screen-async: Screen a case".
Request you to provide us the request headers and response headers of the failed API call.
@vijay.shejawal Requesting your response on this.
I am also writing you an email to understand more on the issue.
4.2k 7 5 6
@vijay.shejawal
You are getting a 400 Bad request or 503 service unavailable for the endpoint "SEQ-screen-sync-individual: Perform Synchronous Screening" because you are sending the incorrect payload.
Can you please confirm if the below JSON payload gives you a success response?
  "groupId":"{
                {Enter your group-id}}",
  "entityType": "INDIVIDUAL",
  "providerTypes": [
    "WATCHLIST"
  "name": "putin",
  "secondaryFields":[],
  "customFields":[]
You can declare your "postData" variable with the above payload.
Kindly let me know if this was helpful.
We are performing SEQ-screen-async: Screen a case and we have observed intermittent failures for some of cases.
Most of our these async calls are in success while 2 to 3% are in failure with connection error as mentioned.
