Connection reset by peer
I'm trying to get going with the WorldCheckOneApi, but I'm unable to even make a proper connection to the server.
For example, using the Postman "SEQ-1a: Get my top level groups", I always get "Could not get any response. The request from Postman is as follows (I have removed the key / signature)
GET /groups HTTP/1.1
Host: rms-world-check-one-api-pilot.thomsonreuters.com
Date: Tue, 14 Feb 2017 16:36:48 GMT
Authorization: Signature keyId="<< REMOVED >>",algorithm="hmac-sha256",headers="(request-target) host date",signature="<< REMOVED >>"
I have done this on both Pilot and production environments, and the same things happens.
I have also tried a
wget https://rms-world-check-one-api-pilot.thomsonreuters.com/
and I get
Connecting to rms-world-check-one-api-pilot.thomsonreuters.com|159.220.25.95|:443... connected.
HTTP request sent, awaiting response... Read error (Connection reset by peer) in headers.
Retrying.
Or doing...
curl https://rms-world-check-one-api-pilot.thomsonreuters.com/groups
gives me
curl: (56) SSLRead() return error -9806
In case it's some network issue, doing
traceroute rms-world-check-one-api-pilot.thomsonreuters.com
results in
traceroute to rms-world-check-one-api-pilot.thomsonreuters.com (159.220.25.95), 64 hops max, 52 byte packets
 1  10.1.16.1 (10.1.16.1)  3.257 ms  1.845 ms  1.275 ms
 2  no-dns-yet.convergencegroup.co.uk (109.232.61.194)  2.937 ms  5.631 ms  5.110 ms
 3  * * *
 4  10.200.0.70 (10.200.0.70)  5.521 ms  2.519 ms  4.941 ms
 5  10.200.0.61 (10.200.0.61)  2.787 ms  2.921 ms  2.780 ms
 6  137.221.191.44 (137.221.191.44)  2.669 ms  2.530 ms  2.450 ms
 7  te-4-3.car5.london1.level3.net (217.163.45.205)  2.578 ms  4.584 ms  4.185 ms
 8  * thomson-fin.edge6.london1.level3.net (212.187.200.122)  6.410 ms  8.616 ms
Thanks!
world-checkworld-check-oneconnectiontracetcp
I've got it... I missed the
/v1/
In the URL.
It would be good to have a better error I think than something that is at the TCP level. Maybe a 404?
3.1k 16 7 7
Hi @edo,
I tested your credentials using Postman and it is working....
If you could email me the output of the "Code" in Postman with your <<REMOVED>> data, then I can help you...
Hope this helps,
Brian
    "id": "<REMOVED>",
    "name": "Acme Services Ltd (Pilot)",
    "parentId": null,
    "hasChildren": true,
    "status": "ACTIVE",
    "children": [
        "id": "<REMOVED>",
        "name": "Acme Services Ltd (Pilot) - Screening",
        "parentId": "<REMOVED>",
        "hasChildren": false,
        "status": "ACTIVE",
        "children": []
